smicha wrote:Approximate costs of watercooling for 4 graphics cards (excluding waterblocks).
- 900D - 350E
- 1xD5 pump - 70E
- fittings and tubing - 50E
- 2x480 rads - 200E
- 8 fans - 100E
- reservoir - 50E
All - about 850EUR
Hi Smicha,
I am getting more and more into the wc stuff
As follow up on your above
- 1xD5 pump - 70E
Going for two pumps is safe when one fails the loops will be still OK having the other one. Benefit of two pumps is also higher flow ofcourse. Is this a good thought?
I am thinking of 2x Swiftech Laing D5 MCP655 (1200lph , €100 for each)
Or is this a overkill?
I am adding up to €100
...but this includes multiplinking between GPU's, and it's all Bitspower then, including fullport, exhaust fitting, et cetera
- 2x480 rads - 200E
I am adding up to 260E
but then that is for external Watercool MO-RA3 9x140 PRO black including foot, grill and fans,
so that is not too bad
- 8 fans - 100E
I am adding up to 150E
but that is the 9 fans (140mm Noiseblocker BlackSilentPRO PK3 - 140mm (1700 rpm)
for the external radiator and might come cheaper
- reservoir - 50E
I was thinking about Bitspower Water Tank Z-Multi Ultra 250 - POM - BP-WTZMU250P-BKCL (€72,95)
Does that hold enough volume for this loop?
And then.. I have to count the other stuff like liquid, sensors, dsiplays, UV lamps, sleeving, pasta, clean kit, tubes, et cetera... so it might be a pricy plan over 1K (excl WB) after all...
But then, I am still in research and I might overkill in some area?
Maybe you have some tips and trcks for the above?
greetz,
