Or ask right away and I'll make sure to help you out
to all the Poser SKIN makers...
...and should you have any questions regarding RedSpec SSS - head over to our official homepage http://redspec-sss.com
Maybe im doing something wrong then... The default skin - you mean the ones from liveDB?
They do not produce the SSS effect atall, and they are really convoluted some of them, to the point
i didnt know where should i apply my textures, because they come looking like a red jello... In poser
achieving skin with SSS and fairly realistic reflection/specular takes about 5 seconds... only reason i
switched to octane is the speed of rendering, and supposed quality of the rendering, but so far i
see that the time i save on rendering im gonna spend just modifying specular effect on the skin because
decent looking skin is made of 20 material mixes, and actually figuring out what which of them does what
and in what proportions, takes forever. I actually bought redspec skin shader (because so far its THE ONLY
one that actually looks like it has SSS effect on it) and im trying to figure out what happens if i change
any values, but i see no change wether i max them out or zero them (particularly in specular area)
I'm highly frustrated... :/
My Artstation profile: https://www.artstation.com/tigersan
Software: Poser 11 Pro, Octane Studio 2020.1.5.104, Adobe Suite
My RIG:
Operating system: Windows 10 Pro 64
CPU: Ryzen 5900x
RAM:128GB RAM
GPU: 2x Nvidia 3090
HDD: 2x WD Gold 7.68TB U2 NVME
My RIG:
CPU: Ryzen 5900x
RAM:128GB RAM
GPU: 2x Nvidia 3090
OMG! Thank you this is what i needed!face_off wrote:The default skin material that the plugin generates for Poser figure skin materials should look better than the best Poser skin shader. If that isn't good enough for your rendering, you can get the RedSpec skin shaders. If you want to create your own - a good starting point is at http://poserphysics.blogspot.com.au/201 ... hader.htmlCan you post a tutorial on how to make skin look like that? I have been really pissed about this... i have switched from poser firefly renderer
and it took five seconds there to make skin look realistic, and its retarded in octane... Makers of octane did not post any decent skin shaders
in live DB... there are few but no clue how to use them they are a color of a jello not skin, and i tried for few hours to figure out where to connect
the color textures, and specular maps and bump maps with no success... :/ its VERY frustrating.
A proper guide with explanation what are effects of each dial...
Thank you!
My RIG:
CPU: Ryzen 5900x
RAM:128GB RAM
GPU: 2x Nvidia 3090
My RIG:
CPU: Ryzen 5900x
RAM:128GB RAM
GPU: 2x Nvidia 3090
Already replied to you in the forums - as stated, new users should possibly look into learning OctaneRender and it's various functions first, before utilizing RedSpec as the material mix is quite complex and difficult to modify afterwards.
Hence the notes we put all over the homepage regarding that
Glad that you could find an applicable option for your situation though! Did you take a look at our RedSpec TGX Wet beta products? http://redspec-sss.com/g2f_wet_beta.html
These shaders were designed to make your characte really look WET - unlike our RedSpec TGX tailored shaders which were developed to give a realistic, dry skin shading option.
Thats fine, for what i need the skin to do, sadly your shader doesnt do much for me, i need it to be simple and look good and default octane shader does it perfectly for me.TRRazor wrote:Already replied to you in the forums - as stated, new users should possibly look into learning OctaneRender and it's various functions first, before utilizing RedSpec as the material mix is quite complex and difficult to modify afterwards.
Now that i have done it propery. Your hair shader on the other hand is VERY useful to me, and the skin even though it doesnt look that good to me taught me many things
about octane
My RIG:
CPU: Ryzen 5900x
RAM:128GB RAM
GPU: 2x Nvidia 3090
My RIG:
CPU: Ryzen 5900x
RAM:128GB RAM
GPU: 2x Nvidia 3090
