I'm not able to render anything
radiance
Sleeping? :),
I suggest you remove everything you installed and redo the whole installation according to the mac installation tutorial video here:
http://www.refractivesoftware.com/demotutorial_mac.html
That's a demo of an installation on a brand new Snow Leopard machine.
Since you have 2 different cards SLI won't work, so it should be disabled by default.
If you do find any SLI related controls, turn them all off. (However i haven't found any SLI controls on mac myself, i'd be interested in knowing where they are or a screenshot of them :) )
And, before you begin testing, use a simple scene out of our testsuite, like the chessscene.
Yours,
Radiance
Colas
Hi Terrence,
I don't know how to uninstall drivers and Toolkit on Osx, I'm going to check this and do what you say.
I forgot to say that i run Osx in 64 bits by default by i started in 32 bits and it's the same.
I start to search how to uninstall drivers.
I'll give you feedback.
Thank you,
Nicolas
MacPro 2010 Octo 2,4Ghz Westemere • 14Go Ram • 1 x GT 120 • 1 x GTX 285 Mac edition • OsX 10.6.5
mathurin
Colas,
Looking at the screen captures you posted, there seems to be the pins on the node, so it seems something has been imported in. it may sound extremely dumb but my question is have you actually clicked on the node to start the rendering process?
Regards,
Mathurin
W7 Pro 64bit | i7 950 @ 3.07GHz | Vertex II 60Gb SSD | 2 x MSI GTX460 Cyclone 1gb | 6gb OCZ Platinum 1333 DDR3 | Max Design 2013 | Octane 1.11 |
Colas
Yes i did it. i would be very happy if i had forget this.... but i think it's a worst problem
Thank you,
Nicolas
Colas
Ok i uninstalled everything and i install Cuda drivers 3.0.14 and then Cuda Toolkit 3.0 = it's not opening Octane, it's written : No cuda capable devices found, existing...
i made an update to Cuda driver 3.0.17 = Octane open but not render.
i made an update with Cuda Toolkit 3.1 = Octane doesn't render
i made another update to Cuda toolkit 3.2 and then = Octane doesn't open and it's written : it's written : No cuda capable devices found, existing...
Then i updated to Cuda driver 3.2 = Octane doesn't render.
So now i'm still not able to use Octane. I hope Radiance will find a trick or with a future update i will be able to render something.
Nicolas
face
The toolkit is only usefull if you are a developer and want to program or analyse you program.
It has nothing to do with some drivers, at least at windows...
face
http://vimeo.com/user2509578
Colas
Hi Face,
I understand but with or without it, Octane doesn't render on my computer.
radiance
Colas wrote:Hi Face,
I think we're running out of options here. :(
Do you have a windows installation via bootcamp to try to see if it's a hardware issue ?
Yours,
Radiance
Colas
Nope i don't have one. I could do it...
So if i don't want to go on windows there's no issue for me right now or for a long time?
Hi Colas,
if I were you, first thing I would do a clean install of 10.6.4, then install the drivers for the GTX 285. Restart, repair privileges, check with Cinebench 11.5 that the graphics cards are properly installed by attaching the monitor before to the gt 120 and then to 285. If everything is ok, install the cuda driver 3.1.14, then the CUDA Toolkit 3.1 and Octane in the end.
