OctaneRender™ Standalone 2.06 [current 2.xx]
roeland
manalokos wrote:When using fog and displacement all GPU's crash after some 12 or 20 samples.
Can you post the messages you see in the log window?
Roeland
grimm
Octane is also crashing on me when I turn on subdiv in the OBJ import section and click on the mesh node. I don't know if it's a problem with the geometry or something else? It's a helmet that my son made, not many polys, about 4700. We are checking for non-manifold polys, etc. If we find some he will fix the mesh and I will try to subdivide again.
emihich
What about the promissed new tutorials ?, they need to be updated anyway.
I understand Otoy is centered towards releases now, like the After Effects plugin.
Tutorials from advanced users are fine too, Mainly covering possible doubts on the new features.
I have issues importing Hair from 3ds Max, for an instance, that are not present at the Max plugin.
bisenberger
Rikk The Gaijin wrote:Did you guys give up trying to fix the displacement? Or there is still hope? :(
Bummer... displacement was the reason I upgraded.
GTX660 3GB, i7-3770K CPU, 16GB ram.
Seekerfinder
There is always hope.
Aragon
manalokos
Hello Roeland
The displacement+fog happens sometimes, when it will happen again I'll send you the log.
I just discovered another possible bug, when you have a orbx on your scene that has an alembic file inside, octane will crash when loading the scene.
Kind regards
Filipe
manalokos
There is an issue with Network rendering:
If I have a machine rendering with standalone, it is still available as a slave on the network,
this can be dangerous when you have many machines as it can cause the render to crash because the machine is forced to make another render at the same time.
manalokos
Another network render issue:
slaves fail when you save an image while rendering.
stratified
grimm wrote:Octane is also crashing on me when I turn on subdiv in the OBJ import section and click on the mesh node. I don't know if it's a problem with the geometry or something else? It's a helmet that my son made, not many polys, about 4700. We are checking for non-manifold polys, etc. If we find some he will fix the mesh and I will try to subdivide again.
Can you provide us the mesh so we can have a look?
cheers,
Thomas
grimm
Thanks Thomas, you have a PM.
Jason
