OctaneRender™ Standalone 1.32
abstrax
smicha wrote:
roeland wrote:If you select the environment, does Octane show a resolution and image type below the file name?
Roeland
It says:
19179x9860 pixels, 96 bpp RGB HDR, 3037804 KB
We found the issue: A safety check in the shader system was overflowing (it's a fairly large image) and because of that, the HDR image got never uploaded to the GPUs. It will be fixed with the next version.
treddie
You guys are the best!!!!
Thanks loads for adding the extra decimal places! Awesome!
Win7 | Geforce TitanX w/ 12Gb | Geforce GTX-560 w/ 2Gb | 6-Core 3.5GHz | 32Gb | Cinema4D w RipTide Importer and OctaneExporter Plugs.
smicha
abstrax wrote:
Roeland
It says:
Thank you Marcus!
MB
To whom it may concern;
Is it in anyway possible to combine an texture hdr lighting effect with the sun in a daylighting environment.
I can not figure out how to rotate an hdr image around the virticle axis, it was quite easy in v1.2, could yo9u point me in the right direction.
thx
Mark
Windows 11, 2x Intel I9, 64GB Ram, 2x GTX 1080 TI, 1 x RTX 380 TI, Oculus Quest 2
Mark - switch the projection of the texture environment image to Spherical, and rotate via the Y axis on the Sphere Transformation slider.
