New version 1.23.2 (SDK 1.37) *** 25.03.2014***
useruser
aoktar wrote:
useruser wrote:no idea what is going wrong but no texture is visible in render any longer( 1.06c)
texture come from livedb? Or is it in your search paths or project paths?
oh sorry! :) after update to 1.06c i forgot to redefine all necessary texture-paths in /settings/paths/. now it works.thank you!
Workstation: Win 10 PRO 64 bit, 3,4 GHZ ,6-cores, 64 GB RAM , 4x RTX 2080 Ti
1. RenderSlave: Win 10 Pro 64 bit , 3x GTX 980Ti
2. RenderSlave: Win 10 Pro 64 bit 2x GTX 980 Ti
Pixelkingdom
Hi Aoktar,
i cannot activate my plugin for cinema. Everytime the program says that i have to activate my standalone version. After that error number 2 is showing up again...."This plugin account is currently activated on another machine.....
Please fix this bug. :)
I cannt use octane in cinema at the moment....
PS: look like the same problems like "ASyme1" but without the crash...
Win 7 64 bit//3xGTX TITAN//i7 980//12GB//Cinema 4D R15 Studio
http://www.kingsandchameleon.de
Pixelkingdom, did you tried to deactivate from web site? Did you changed your os or hardware?
Bolos
Is there an OSX version around ?
I'm so disappointed, C4D keeps crashing and crashing, really can't work with Octane.
Coucou!
Pixelkingdom
No i didn't change the os. A few weeks ago i added 2x Titans...
Ok i tried deactivate from website. Now the RC2 is working again. But version 1.07a isn't working. Always this error is displayed" Error2: This plugin account is currently activated on another machine....."
I wrote some warnings on first page about this version. This is for only previewing version. This means please don't use on any jobs, i can't give a guarantee about backward compitability or stability. New sdk contains some big invisible changes, even plugins. We are still working to complete this changes. Also New Octane Api is still not stabile stage.
Bolos: What's your specs? Are you sure that you did a correct install? I wrote that some scenes which was done by previous version can cause problems. Did you tried on new scenes?
Pixekingdom: i'm not sure about this problem. I can help to you next day for this
Is there anybody get it worked without problems?
Bolos
I finally downloaded the C4D plugin for C4D R13 on my customer area and it seems to work again now.
But I'm using C4D R15, strange.
Coucou!
TBA3D_70
OS X version ???
Osx version is not yet available.
FooZe
Yes, this can happen. If there are any changes to the security/licensing system between octane core/SDK versions that the plugin is built on, then different versions may generate a different machine ID (leading octane to think you are on a different machine). It means you will need to de-activate and re-activate every time you change versions.
(Usually we try to keep changes to the licencing system to a minimum so this doesn't happen)
I hope that makes sense? :?
(and sorry for the inconvenience)
Chris.
