A new set of eyes.
gordonrobb
I've been looking at doing a similar thing with eyes, although no where near as detailed. But I have been messing with a shader that allows for a lot of control over eye colour in various ways.
You say color is controlled with one gradient. Can you give me some idea how? I have no idea how gradients work in Octane if I'm honest.
treddie
Scary real! That texture for the white of the eye is awesome. And the iris really looks like a magnified image of one.
Win7 | Geforce TitanX w/ 12Gb | Geforce GTX-560 w/ 2Gb | 6-Core 3.5GHz | 32Gb | Cinema4D w RipTide Importer and OctaneExporter Plugs.
gordonrobb
They are really good. Any chance of some insight into what you mean about using the gradient to control the colour? I'm trying to translate to doing something similar in the LW plugin.
ElBloko
Sure thing. If you have ever used gradient maps in photoshops or ramps in any other 3d package, it works the same way.
Feed any texture to be used as a scalar texture to a gradient node so you can remap its values using the gradient node shaping function.
Quick pic.
The gradient node interpolates (linearly or not) between a start and an end value and remaps your entry values (input texture) to the new user provided ones.
You can create as many intermediate values as you need, It is also to be noted that once a new value (and its position on the ramp) is created,
it becomes available for modification. You can connect any kind of images, procedurals or geometry samplers to those values and create extremely complex effects.
I hope that helps.
xxdanbrowne
OK so if I try to use my own dumbed down paraphrasal of what you're doing here:
You take a grey scale image
You plug it in to a gradient node.
It remaps the grey scale image to the corresponding colors along the gradient in the gradient node.
You get an output colorized image which you can apply as a texture.
I tried to use a gradient node for the edge of an atmosphere for a planet and failed miserably. Maybe with your clearer explanation I can get it to work.
gordonrobb
Got it thanks.
I was doing something similar but with the image, an RBG value and a mix node. Not sure which is best/easiest/faster to render :)
RealityFox
Oh this was really useful for me. I intend on making a portrait soon so this will really help when it comes down to the eyes. Now you said you sculpted the eyes, so I presume you made a texture from it to map it onto the eyeball? Please make your tutorial soon! Seems like a really good process for creating eyes.
Rikk The Gaijin
I just leave this here ;)
ElBloko
Rikk The Gaijin wrote:I just leave this here ;)
Very nice! This is really clean indeed.
nildoe
Rikk!!
you are SICK!!!!!
I REALLY THOUGHT you were showing some reference footage or something! OMG!!
Nildo
Corei7, 6x GTX1070 (2 Inside and 4 in a CUBIX Xpander), 32GB Ram, Win10 64Bit Home, 3dsMax2017 64Bit, Octane for max 3 and LOVING IT!!!!
MSI GT72S 6QE Dominator Pro G win10Home, gtx 980m.
Return to “Works In Progress”
