NEW : Preview of OctaneRender 1.5
ardian_ian
OH MY GOD!!!! great stuff man!!! thanks to all octane team!!!
Win 7 ultimate 64 | Geforce GTX570 + Geforce GTX570 | i7 2600K @4.8GHz | 8GB
FrankPooleFloating
For anyone who had this fly under their radar - should be very useful for Alembic:
https://www.lightwave3d.com/chronosculpt/
ChronoSculpt is a powerful new stand-alone application that revolutionizes working with animation and dynamic simulation cache files from any application by allowing you to use sculpting and transformation tools over time. ChronoSculpt also introduces a radical new geometry engine based on our “Hydra” technology which allows the deformation and manipulation of 8 to 10 million polygon objects with ease.
Using industry standard vertex cache files in Alembic, LightWave MDD, or Autodesk Geometry Cache formats you can easily paint out errors on your dynamic simulations or even completely change the look of a character either with layered sculpting “clips” in the timeline or globally to affect every frame in your cache animation.
ChronoSculpt also allows you to export any frame from your sculpt or deformation directly to a LightWave Endomorph or OBJ object file (for blend shapes in Autodesk Maya).
ChronoSculpt could potentially save you hours of work by allowing you to quickly make changes to the baked dynamic simulation cache files to address simulation jitter, soft body penetrations, or to remove stray simulation pieces and get the shot out the door.
Last edited by FrankPooleFloating on Wed Nov 20, 2013 2:30 am, edited 1 time in total.
pixelrush
>Octane is a render engine, not...
OK fair enough, it has turntable and sun transit though, so basic walk through or WASD would be nice. Rather than rendering images out Octane could be used as a real time presentation/exploration tool for architects and interior designers or where the client could quickly choose their own inspection path....extra points for finding and killing aliens in your concept house.. :P
It seems however as though this scrub through capability is Alembic specific. Blender doesn't have Alembic...might be ages coming too and of course it may not play well with the plugin/API either :roll:
Anyway I know there is no point asking for stuff. :cry:
Edit: movie directors might also use this to plan and discuss shots or alternatives... just thinking open ended and laterally :)
Octane v1.55
RayTracey
ch0pper wrote:ok just a quick question if you could answer this for me
Hypothetically if I have an entire scene that say in 3-D studio Max with octane plug-in
Could I export that entire scene to say cinema 4D.
And it would export all the cameras all the lighting all the objects all the shaders.
etc?
(Yes I do understand this is just for the stand-alone version at this time but I would expect this to be exported out into the plug-ins at some point)
Yes, it should be possible to resume work on scenes that were created with one plugin (e.g. Octane for Max) in another plugin (e.g. Octane for C4D).
abstrax
RayTracey wrote:Yes, it should be possible to resume work on scenes that were created with one plugin (e.g. Octane for Max) in another plugin (e.g. Octane for C4D).
Just to make things clearer: The above works only if the plugins provide the functionality to convert a loaded Octane scene into a host application scene, which is a big task and probably won't happen anytime soon, but that depends on the plugin developers.
ch0pper
yes i under stand that as long as it going happen at sum point :D :D :D :D
W7 64 bit |I7-3970X | GTX 780 X2(6GB) GTX 780TI X2 | 64 GB DDR3 RAM
Real Skin & real hair for Poser / DAZ Studio OctaneRender/iray - coming soon
cfrank78
Maybe you guys should do it like nextlimit Maxwell. They will soon bring maxwell 3.00 out and they bring every day a feature video with one of its new features. This bringts hundrets of new clients :-)
Just a business idea!
Kind regards Chris!
MattRM
Just Awsome !!!!
Think models will be animate with the same technologie ?
Just Greats !!!
radiant
Looks like i have some work cut out for me with this release :D
Feature galore 8-)
Win8 Pro 64bit ULT|Intel Core i7 3930K|3.20 GHz|32 GB RAM|GTX 590|UD5 2011 socket||2x TB HD||Master Cooler HAF X||Blender 2.6||Maya 2012||Octane|
dionysiusmarquis
Is this the same Motion Blur technique used in the plugin versions? Seems different, as the plugin sub frame approach isn't visible in live view so far.
