Octane Render Crashes
- bariscan90
I've installed cuda toolkit 3.0 but don't know where to put those files to.And the file that nvcuda.dll is not exist in the cuda toolkit 3.0 so,that doesn't change my cuda version i think.
Intel i7 930 2,96ghz
GA-X58A-UD3R
Corsair 2000Mhz cl9 xms3 12GB Ram
Gigabyte GTX 460 OC edition,additionaly overclocked :
Core Clock : 825 mhz
Shader Clock : 1650 mhz
Memory Clock : 3600 mhz
High Power 850 Watt PSU
Windows 7 Ultimate
GA-X58A-UD3R
Windows 7 Ultimate
matej,
I told him to remove the toolkit because it isnt needed and in other cases has stuffed things up
we are trying to make progress here not go backwards
because you are so helpful I'll leave you to sort his problem out.
Octane v1.55
Octane v1.55
- bariscan90
Hehe,how about the driver 258.56 ? I couldn't find any info about it ?
GA-X58A-UD3R
Windows 7 Ultimate
GA-X58A-UD3R
Windows 7 Ultimate
I thought if the drivers already contain needed CUDA files, but those are too new (and supposedly causing problems), installing the older toolkit would overwrite them.
He cannot make things worse that are already, so everything is worth a try
cgmo.net
cgmo.net
- bariscan90
I install the cuda toolkit 3.0 but setup makes the destination folder to c/cuda folder so there was nothing there before,and no overwriting ofcourse in this way,how to overwrite them??
GA-X58A-UD3R
Windows 7 Ultimate
GA-X58A-UD3R
Windows 7 Ultimate
If the installer doesn't do it automatically, then probably it's not supposed to happen. I'm not giving additional wrong suggestionsbariscan90 wrote:I install the cuda toolkit 3.0 but setup makes the destination folder to c/cuda folder so there was nothing there before,and no overwriting ofcourse in this way,how to overwrite them??
Leave it as it is, and see what Radiance has to say.
cgmo.net
cgmo.net
- bariscan90
No reply from him yet,hmm.Waiting.And thank you
GA-X58A-UD3R
Windows 7 Ultimate
GA-X58A-UD3R
Windows 7 Ultimate
He is usually pretty active here, it is the weekend now though and he is supposed to be taking it easy after his illness.
Its just a bit unfortunate about the driver availability I think.
I assure you the demo does work and the commercial version does as well.
Sorry if the delay in finding a solution is frustrating your interest in Octane.
Every now and again we have a gotcha like this but it is usually resolved if not by a passing member of community by Refractive themselves.
If Radiance hasnt seen this thread and replied by Monday I'll send him a PM about it
Octane v1.55
Octane v1.55
Please remove the entire cuda toolkit and SDK directories from your system,
and then install the Cuda 3.0 toolkit, and the latest drivers for your linux brand from the nvidia homepage.
There's also a demo video to install here: http://www.refractivesoftware.com/demot ... linux.html
Radiance
Radiance
