error with demo and cinema 4d plugin
vedushi
It doesnt matter, I tested it even without textures and get the same cuda error 700
Also tested:
1st method:
Gpu0 = off
Gpu1 = on
2nd method:
Gpu0 = on
Gpu1 = off
3rd method:
Gpu0 = on
Gou1 = on
I mostly use big hdri's like 10.000 x 5.000 px
And if octane cant handle with such big hdri's than I can say that Plugin is useless.
I've tried also to loggten the Scene with a daylight. The same error. :(
I would love to begin working with octane like a pro and not to waist time like I do till now.
Pease
MSI MPower Z87 - i7 4770 3,5GHz - 32gb Corsair RAM - 2X Gigabyte GeForce 780 Ti - 256 SSD Samsung
Me and many people use it without any problem. I suppose, this is related with HW and octane. Post your problem to customer support, also i'll do same.
vedushi
Oh, this is your help. You guys are making this c4d-plugin and should know what that mean. whether its a hw-problem or plugin-problem. Otherwise I dont know why the plugin has a render-log!? Im very confuesed. I paid a lot of money for hw and sw. Now, I just want to use it. Thats all.
vedushi wrote:Oh, this is your help. You guys are making this c4d-plugin and should know what that mean. whether its a hw-problem or plugin-problem. Otherwise I dont know why the plugin has a render-log!? Im very confuesed. I paid a lot of money for hw and sw. Now, I just want to use it. Thats all.
thanks, but this is out of my speciality. I'll forward to devs of Octane, but now they are in holiday for Easter
abstrax
vedushi wrote:I have the same Problem with my 2 GTX 780 ti's... I allways get a Render Failure! Thats not annoying that bullshit. I dont mean the plugin is bullshit. Guys I cant work. It costs a lot of Projects I cant accept. Thats a lot of Money.
CUDA error 700 on device 0: An exception occurred on the device while executing a kernel. The context cannot be used anymore and must be destroyed. All existing device memory allocations from this context are invalid and must be reconstructed.
-> Failed to unload module
I hope you guys will help me. The Cards are new and tested. Im playing a lot of games and do not get Errors or Fail-Messages and stuff like that.
Cinema 4D R14 v1.51.2 (Win 7 64bit) = Render Failure!
Cinema 4D R15 v1.51.2 (Win 7 64bit) = Render Failure!
Octane Render 1.51 (Win 7 64bit) = 2 GPUs (1 Failed)!
Could you please calm down and fix your tone? Thanks.
The next time you see an error could you please post/send us a full log. CUDA error 700 just indicates that the current CUDA context is broken and can't be used anymore. Usually something bad happened before and the first CUDA error message is usually the indicator of what really went wrong.
qagraphics
Hey Abstrax,
I am currently using 2 GTX Titan black 6 gb and 2 of the GTX 780 TIs and also getting the same error code. Here is my log info
--------------------------- EXPORT LOG ---------------------------
Export materials time= 0.552 ms
Collect objects time= 0.065 ms
Meshes creation time = 19.437 ms
Octane voxelization time = 0 ms
Sending to Octane engine time = 1.819 ms
Total export Time = 84.621 ms
Tried to access null node
Tried to access pin via an invalid ID P_INPUT (65)
Tried to access null node pin
Can't connect node 'Octane Material' (NT_MAT_DIFFUSE, 0000000162FD8740) to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node 'Copper' (NT_UNKNOWN, 000000000ED90F70)
closeOctaneDialog
---->>>> closeRenderDialog 0x0000000000000000
STOP and RESET
closeOctaneDialog
Export materials time= 0.965 ms
Collect objects time= 0.059 ms
Meshes creation time = 10.785 ms
Sending to Octane engine time = 0.091 ms
Total export Time = 80.808 ms
Export materials time= 0.203 ms
Collect objects time= 0.033 ms
Meshes creation time = 15.303 ms
Sending to Octane engine time = 0.066 ms
Total export Time = 71.813 ms
Export materials time= 0.354 ms
Collect objects time= 0.037 ms
Meshes creation time = 11.586 ms
Sending to Octane engine time = 0.059 ms
CUDA error 719 on device 0: Error code unknown.
-> Failed to copy memory to device.
CUDA device 0: Failed to load data of data texture 4 of context 0 onto device
-> Failed to deallocate device memory
-> Could not get memory info
<<< Render Failure >>>
Total export Time = 67.849 ms
-> Failed to deallocate device array
Export materials time= 0.211 ms
Collect objects time= 0.432 ms
Meshes creation time = 12.871 ms
Sending to Octane engine time = 0.055 ms
Total export Time = 92.875 ms
Export materials time= 0.202 ms
Collect objects time= 0.032 ms
Meshes creation time = 14.653 ms
Sending to Octane engine time = 0.062 ms
Total export Time = 70.844 ms
Export materials time= 0.196 ms
Collect objects time= 0.436 ms
Meshes creation time = 12.403 ms
Total export Time = 68.843 ms
Export materials time= 0.225 ms
Collect objects time= 0.461 ms
Meshes creation time = 11.387 ms
Sending to Octane engine time = 0.052 ms
Total export Time = 71.869 ms
Export materials time= 0.256 ms
Collect objects time= 0.04 ms
Meshes creation time = 17.587 ms
Sending to Octane engine time = 0.073 ms
Total export Time = 73.883 ms
Export materials time= 0.31 ms
Collect objects time= 0.044 ms
Meshes creation time = 11.438 ms
Sending to Octane engine time = 0.069 ms
Total export Time = 70.841 ms
Export materials time= 0.262 ms
Collect objects time= 0.045 ms
Meshes creation time = 16.102 ms
Sending to Octane engine time = 0.051 ms
Total export Time = 74.876 ms
Export materials time= 0.29 ms
Collect objects time= 0.042 ms
Meshes creation time = 12.533 ms
Total export Time = 68.877 ms
Export materials time= 0.204 ms
Meshes creation time = 13.408 ms
Sending to Octane engine time = 0.057 ms
Total export Time = 69.889 ms
Can't connect node 'Octane Material' (NT_MAT_DIFFUSE, 000000016137E3C0) to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node 'Copper' (NT_UNKNOWN, 000000000ED90F70)
Can't connect node 'Octane Material' (NT_MAT_DIFFUSE, 000000016137F8C0) to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node 'Copper' (NT_UNKNOWN, 000000000ED90F70)
-> Kernel execution failed (dl)
CUDA device 0: Direct lighting failed
qagraphics
The think that is odd is its hard to replicate. I am trying now again and it seems to be working but often when I start renders at night ill have the same errors. I am starting regret getting these 780s for I think their may be stability issues with them...
coilbook
are you still having problems.
mine freezes at around frame 30 with this message
CUDA error 700 on device 0: Error code unknown.
coilbook
lol Mine does at night too
