Thanks Radiance for keeping us updated!
Will the RLT be able to calculate correct shadows generated by objects with opacity maps? Since caustics demand too much time to calculate, isn´t be interesting to have a button to disable it?
Diogo
Octane 2.3 final will not have MLT.
- Diogo Moita
- Contact:
i7 930, 12Gb, 2x GTX470
http://www.3dm.com.br
pixie -> you need to use a scene like an interior with glossy, diffuse and specular materials, to see the difference.
a simple diffuse only object won't show the difference much.
rgigante -> no, SPPM is biased, it cannot render spectrally as it stored photons, and is not implementable fully on the GPU, only ina hybrid way, where you have the CPU working along, and you suffer from the PCI-e speed and lag bottleneck, so it's really not that good an algorithm.
andrian -> no, it's meant for rendering finals. you will be able to navigate, but it won't be a smooth experience
diogo moita -> yes
Radiance
diogo moita -> yes
Radiance
- Elvissuperstar007
- Contact:
Will there once a button in the sun ...... volumetric light?
animation volumetric light and animation light
Last edited by Elvissuperstar007 on Fri Sep 10, 2010 3:47 pm, edited 2 times in total.
Well it's not like it's a diffuse material either. I was under the impression that under direct light conditions MLT was to be many times slower, in interiors I know that MLT excels PT by a great margin, and we aren't talking on fireflies. I've set a scene where PT could or should easily excel and yet didn't, if I was to put specular, glossy materials MLT would actually trounce PT.radiance wrote:pixie -> you need to use a scene like an interior with glossy, diffuse and specular materials, to see the difference.
- Synthercat
You almost gave me a heart attack there Radiance! (Just kidding)
Reading your post I could almost here Patrick Stewards voice go "...to boldly go where no renderer has gone before!"
To tell you the truth after the first 2-3 days of using Octane I thought to myself "damn!?! I don't think I can commercially use this renderer yet but I am happy to practice with it till it becomes more... complete"
But then I remembered that you guys (I bet no girls work for refractive) did make clear that THIS IS A BETA STAGE. So I can't and won't blame (as long as I see a complete version even in 2 years from today)
I am really excited to be part of something that innovative and new.
I have thanked you in 2-3 other forums and I am privileged to thank you again here "face to face"
to make a long story short... you got my FULL support Radiance.
PS. I wish my C++ knowledge was better that the infant level that they are
PS-2 : "Site bug" foung! : Please remember to remove the "QMC sampling and MLT sampling**" on the features section
Linux Mint 19.3 | GTX-1080Ti | AMD FX-8320 (OCed 4.4GHz) | 16GB RAM
pixie wrote:Well it's not like it's a diffuse material either. I was under the impression that under direct light conditions MLT was to be many times slower, in interiors I know that MLT excels PT by a great margin, and we aren't talking on fireflies. I've set a scene where PT could or should easily excel and yet didn't, if I was to put specular, glossy materials MLT would actually trounce PT.radiance wrote:pixie -> you need to use a scene like an interior with glossy, diffuse and specular materials, to see the difference.
Just take a glossy suzanne on a plane, with a sunsky shining brightly on it, and the sunlight is covering 1/3rd of your suzanne.
compare PT against MLT and you'll see the difference.
Radiance
Hi, volumetrics require the engine to be completed first, so they will be added in octane 2.0Elvissuperstar007 wrote:Will there once a button in the sun ...... volumetric light?
Radiance
Will this give advantage to PT? An infinite light and indirect ligth?radiance wrote:Just take a glossy suzanne on a plane, with a sunsky shining brightly on it, and the sunlight is covering 1/3rd of your suzanne.
Radiance
PT will clear up the noise way faster than MLT.pixie wrote:Will this give advantage to PT? An infinite light and indirect ligth?radiance wrote:Just take a glossy suzanne on a plane, with a sunsky shining brightly on it, and the sunlight is covering 1/3rd of your suzanne.
Radiance
but, you'll have fireflies and it might take a long time to see a complex caustic.
Radiance
andrian wrote: Ok, this rise the question, since the new algorithm is similar to bidirectional path tracing , will we be able to navigate our scene as we do now with path tracing?
Ok, are we going to have an option for setting the renderer at 60 FPS for example in order PC to be useful during rendering, as was being told it's doable for MLT algorithm ?radiance wrote: andrian -> no, it's meant for rendering finals. you will be able to navigate, but it won't be a smooth experience
Radiance
Vista 64 , 2x Xeon 5440 - 24GB RAM, 1x GTX 260 & I7 3930 water cooled - 32GB RAM, 1 x GTX 480+ 1x8800 GTS 512
CGsociety gallery
My portfolio
My portfolio2 - under construction
Web site
Making of : pool scene - part1
CGsociety gallery
My portfolio
Web site
