OctaneRender® for Poser beta WIN - build 1.14a [OBSOLETE]
Nod64
Excellent. This is the excuse that I needed to reinstall Poser. :mrgreen:
Erick
I guess I found a minor thingy ..
I opened the LiveDB and accidentally double-clicked on the empty space in between the two material columns and an error window popped up.
elenacalderas
I just tried to paste an image into the diffuse node of a glossy material (which held an RGB node before) and got this message:
Traceback (most recent call last):
  File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\SetupForm.py", line 1582, in MenuSelectionCb
  File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\MaterialManager.py", line 865, in MenuCommand_PasteReplaceMaps
  File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\MaterialManager.py", line 906, in Paste
NameError: global name 'newNode' is not defined
Edit: Once that happened, it also throws out errors when you then try to manually put an image into the diffuse node by selecting "image".
Win 10 Home x64 / NVIDIA GeForce GTX 1070 8 GB / (Intel i7 2.8 GHz) x8, 16 GB RAM / PoserPro 11.2
Zay
Loading a .poc file still crashes Poser2012 Sr3.1.
Win 11 Pro | i5 12600K | 32GB ram | 2x GTX 1080Ti + 3080Ti - studio driver 581.57| Modo/Blender/ZBrush/Daz/Poser
RGUS
When I refresh the Octane scene from Poser, the materials in the Octane Scene are all screwed up. Reloading the scene [geometrygroup] fixes it... is this normal?
WEB: http://rgus.deviantart.com/
GPU: NVIDIA GeForce RTX 3090 Ti
RAM: 64GB
CPU: 12th Gen Intel(R) Core(TM) i9-12900K 3.20 GHz
OPERATING SYSTEM: Windows 11 Pro
OCTANE PLUGIN VERSION: 2025.6.0.4.09 Prime BETA
DAZ STUDIO VERSION: 4.24 Pro Edition (64 bit)
Erick
Zay wrote:Loading a .poc file still crashes Poser2012 Sr3.1.
Just had a quick test on this ... same result here. A freezing Poser.
ch0pper
yep same here Loading a .poc file still crashes Poser2012 Sr3.1.
crash
W7 64 bit |I7-3970X | GTX 780 X2(6GB) GTX 780TI X2 | 64 GB DDR3 RAM
Real Skin & real hair for Poser / DAZ Studio OctaneRender/iray - coming soon
I have fixed the loading of POC files. However I've found an issue with pasting nodes which is proving harder to rectify. Will hopefully have a fix uploaded and available in the next hour.
I have refreshed the installer at the top of this thread. Pls re-download and install to fix the following....
1.14a5
- Fixed issue where importing material collections was crashing Poser
- Fixed issue where pasting nodes was causing a python exception
- Fixed issue where double-clicking a "non-item" in the LiveDB would raise a python exception
- Fixed issue where pasting a floattexture was not copying the texture value
- Fixed issue where pasting a material was raising a python exception
It doesn't seem to activate them in real time. The only way I can seem to activate them is close to viewports
And reload the window.
I wonder if it. This is possible to do in real time when we press apply. As this would make quite a few advantages
Chopper - are you clicking the "Apply" button after ticking/un-ticking the "Active" checkbox?
Deane, what does "refresh the Octane scene from Poser" mean? What button/menu item are you using to do this?
"the materials in the Octane Scene are all screwed up" - not sure what you mean by this? Can you provide a screenshot pls?
ch0pper
The multiple graphics card bug.
. It's definitely a bug, it only seems to let me select my first graphics card.
even if I press on the apply, does not select the graphics card and utilise them
Even when I close than the viewport and tick all three graphics cards. boxes
It seems to default back to my first graphics card.
Basically, it's working on the first graphics card .
Not the other 2.
I could in previous versions use all three graphics cards
Basically , I've used the GPU monitoring programme . The first graphic card is it 99% whilst rendering
the other 2 cards even though the boxes are ticked stay at zero , so there's absolutely no load on never two cards
Even though the boxes are applied and ticked
Return to “Poser”
