yep, try it...
texture all in modeler, and export OBJ.
Lightwave 3D Plugin v0.3
3 x RTX 3090 / 1 RTX 4090
96 GB RAM
Threadripper
96 GB RAM
Threadripper
Just tried the LW plug-in. The .obj exporter works much much better than LWs native, that most of the time crashed Octane.
Questions though.. I saw layer support. But I only get one layer (the first) working.. I also tried different objects but that didn't seem to work. So I only get one object exported from my layout scene.
I will continue to explore the plug-in though, fantastic work sofar
Win7, i7 980 Hexacore, 24GB RAM, 3xEVGA SC 670 GTX 4GB
It works fine here, could you please share content?PeterCGS wrote:Questions though.. I saw layer support. But I only get one layer (the first) working.. I also tried different objects but that didn't seem to work. So I only get one object exported from my layout scene.
GTX260 Seven 64bit
I'm Superfrog
I'm Superfrog
i'd like to have some better infos about this plugin, i read the infos but these are not clear to me;
- what does "use exsisting project" exactly do ? Once i write path and project name, if i activate this it means it will reuse settings from a previously exported project and update only objects ? or what ?
- Not clear what POI does. Supposing what's the number and what's the list ?
Again, i hit render but nothign happens, i get only obj export. I tried with many scenes.
LW 9.6 64bit here on Windows Seven 64.
thanks,
Paolo
thanks,
Paolo
I7 960 3.2 GHZ - 6GB ram - GTS 250 display only - Asus GTX 470
POI is the same as camera target in octane.
If you set existing project that for example all ready have set up lightning etc this will be used when rendering a scene.
Could you please try attached files, load the scene, set the POI to the null and hit render. Let me know if it works for you.
- Attachments
- testproj.zip
- (3.16 MiB) Downloaded 418 times
GTX260 Seven 64bit
I'm Superfrog
I'm Superfrog
it didnt work so i made some further tries, and i discovered the issue.
EXE path cannot handle spaces, in fact i had "C:\Program Files\Refractive Software\OctaneRender_pre23_4\octane.exe" and it didnt work, then i put Octane into "c:/octane/Octane.exe" and it went OK.
So i wonder if you can do anything about it, it would be annoying having to install Octane i root just because of this
thanks
paolo
thanks
paolo
Hm that's very strange. Works fine for me with spaces.
- Attachments
- OctaneExport.zip
- (77.98 KiB) Downloaded 398 times
GTX260 Seven 64bit
I'm Superfrog
I'm Superfrog
Hello I'm new here,
I'm doing some simple test with a plane and a cube before to start with real project..
With your plugin i can' get any uv to be read by octane..if I export using the modeler plugin it works!
Do i miss something?
attach the scene here and I'll take a lookspigolo wrote:Hello I'm new here,
GTX260 Seven 64bit
I'm Superfrog
I'm Superfrog
