OctaneRender standalone 1.10 released
octanetry
great job
the only problem is my inability ;) ...
PS there are some tutorials or books to improve the materials in interior scenes??
palhano
So far so good!!!
Now we need some network or distrituted render support to render full hd walkthrough animations.
Its not realistic to fire multiple copies of 3dsmax with octanerender plugin and the standalone render over 30 computers to get the job done!!!
BoyAndRobot
Hmm I got one problem here. I tried this new version with the example demo scenes (available in the OTOY webpage). for RenderTarget PT and RenderTarget DL, the Octane can render. However, when I tried the RenderTarget PMC, it could not render, there's this error message below the preview rendering window : 0 Textures, 145577 Tris, 1 Meshes, GeForce GTX 285 (failed), 30.1/1745/2048 MB. (this is the spaceships.ocs demo scene)...
abstrax
BoyAndRobot wrote:Hmm I got one problem here. I tried this new version with the example demo scenes (available in the OTOY webpage). for RenderTarget PT and RenderTarget DL, the Octane can render. However, when I tried the RenderTarget PMC, it could not render, there's this error message below the preview rendering window : 0 Textures, 145577 Tris, 1 Meshes, GeForce GTX 285 (failed), 30.1/1745/2048 MB. (this is the spaceships.ocs demo scene)...
See here and here.
BoyAndRobot
I see, thanks for the info :)
amathews9518
1.1 won't import mesh.
I am getting failed to load node:post processing error message
I use the lightwave exporter.
Now 1.0 will not work from lightwave any more.
It has worked flawlessly before installing 1.1
I can fire up 1.0 on its own and load file fine.
1.1 will not load files either way :(
W764 2xE5 2650 3-780(3GB) + 780TI(3GB) Asrack EP2C602 40gb Lightwave & Chief Architect
abstrax
amathews9518 wrote:1.1 won't import mesh.
If you get the error message "failed to load node:post processing" you tried to load a scene that was saved in a version higher than 1.00 (presumably 1.10) in an older version of Octane (<= 1.00). Please check the version in the title bar of the Octane application window that gives you the error message.
Marcus
amathews9518
It is a problem with the Lightwave Scene exporter.
If I save as a obj object and load in 1.1 as a mesh it works.
Is there a version of the Lightwave exporter that works with 1.1?
abstrax
amathews9518 wrote:It is a problem with the Lightwave Scene exporter.
It's more likely a problem with Octane since the current exporters should just work with any recent version of Octane. The next test release (1.11) will have a bug fix in the OBJ parser. Please try with that version, when it becomes available.
It would be even better if you could send us the exported scene that doesn't work so we could verify before we release that this issue is solved.
Marcus
amathews9518
Here is the files that work in 1.0 but not in 1.1
Klein.zip
(3.11 MiB) Downloaded 664 times
