Ok, modifying the daylight parameters works.
Another question, not directly related to Poser version, but is there a best practice in terms of handling hot pixels? Using the hot pixel removal feature is good, but blurs the image slightly.
When I have a few near white reflective materials I can not get rid of the hot pixels even at 30,000 samples? Is there a better way?
OctaneRender® for Poser beta - build 1.02r [OBSOLETE]
Hi Peter
There definitely seems to be the rare material/light setups where it doesn't matter how long you leave the render. In these cases I've cheated and rendered with a high caustic_blur value which seems to help in the majority of cases - but there is some blur too. If the hot_pixels are due to light transmitted through glass, dropping the "indirect_light_importance" seems to help too. A few pure white materials put together magnify the light if there is too much light. I guess it's easy to put color 255/255/255 into a material, but hard to actually get something that white in the real world.
I feel like the student giving advice to the teacher....so I will stop now.
Got this error when picking a material in Posers material room :
But I could keep in working.
Traceback (most recent call last):
File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\OctanePlugin.py", line 6394, in EventTreeSelection
File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\OctanePlugin.py", line 4310, in AddControlsToNodePanel
File "D:\Poser Pro 2012sr3.1\Runtime\Python\lib\site-packages\wx-2.9.1-msw\wx\_gdi.py", line 130, in __init__
_gdi_.Colour_swiginit(self,_gdi_.new_Colour(*args, **kwargs))
OverflowError: in method 'new_Colour', expected argument 1 of type 'byte'Win 11 Pro | i5 12600K | 32GB ram | 2x GTX 1080Ti + 3080Ti - studio driver 581.57| Modo/Blender/ZBrush/Daz/Poser
Seems like I can't enter LiveDB. Getting this error :
File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\OctanePlugin.py", line 5350, in MenuSelectionCb
File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\OctanePlugin.py", line 7819, in __init__
KeyError: 39Win 11 Pro | i5 12600K | 32GB ram | 2x GTX 1080Ti + 3080Ti - studio driver 581.57| Modo/Blender/ZBrush/Daz/Poser
Zay, there has been another report of this. I suspect a new material has been added which the plugin is having an issue with. Maybe a special character in the name. I will sort it out tomorrow.
Regarding the LiveDB error - there appears to be a corrupted category that has been added to the LiveDB. I will code a fix so that it ignores this new category and release it in the next 24hrs.
Hi Zay. Do you always get this error when you click that material? Or was it a one-off?Got this error when picking a material in Posers material room :
[deleted]
It was one of those one time bugs - so far.face_off wrote:Hi Zay. Do you always get this error when you click that material? Or was it a one-off?
Got another. I get this CUDA error after rendering animations for a couple of hours. It's happend twice now. Same error.
Opening OctaneRender for Poser Setup Dialog
CUDA error 999 on device 1: An unknown internal error occurred.
-> Kernel synchronization failed
CUDA device 1: Failed to run post-processing
I have updated the 1.02r installer to rectify this issue. Pls re-download from the link at the start of this thread..KeyError: 39
Cuda error 999: Zay - is there any possibility that it's a heat issue?
