Preview of OctaneRender for Cinema 4D
hi aoktar,
sincerely i don't know if it could function or not, but in octane, if you want to hide a portion of geometry, you could assign a material portal node with his option disabled. maybe is possible to connect this feature with the compositing tag :roll:
nehale
is Full motion Blur supported in this plugin?
Regards
Nehale
Windows 10 x64 | 2x GTX680 | i7 990X | 24GB
Cinema 4D R17 Studio + 3Ds Max 2017
OctaneRender™ for Cinema 4D 3.01 + OctaneRender® for 3ds max® v3.14
hi,
the plugin is connected with the standalone, you can't expect a feature that is not present in octane itself. when full motion blur will come, we could have it in c4d also ;)
nehale
bepeg4d wrote:hi,
according to this video i thought it already was available https://vimeo.com/49507719
Regards
Nehale
Full motion or object motion blur not available I think, may be come with a update. Then we should have. Octane may be support camera matrix motion blur.
For visibility we can have to do some special tweak with materials. Also vray not supports. But o have a idea for that.
But need extra effort.
César
Excellent, thanks a lot for your work, Aoktar !
Will we have the node manager, or the possibility to import OCM files ?
a node manager may be a next step, it's not soo important for me.
OCM files directly can be used. Also now will have all octane texture nodes in material editor and you can use as octane.
ashurao
Yeahhhhhhh,
Thank you, thank you so much for this christmas gift. :D I'm very excited to use this plug-in, especially for animation. Yeah
Mac Pro 2010 6 cores 3,33 - Mac OS 10.11.6 - 16Go - GTX 780 3Go and GT 640 4Go - Archicad 19 - Cinema 4D R17 Visualise - Octane Render V3
SpeedAbuser
Wow! This is great!
I love the integration with native C4D materials, that makes it all much more useful in production. Blurry reflections in almost realtime inside C4D?! Unreal!!
Is it going to be possible to save out animation sequences where render subdiv limit or time limit for each frame can be set?
I'll post some extra info soon. i spend some effort to make Octane as a internal renderer like default renderer. You can render directly in viewport or picture viewer for animations. And there is no different setup for subdivs. Only limit is gpu memory. New gpus is enough most scenes. Also you can taste of instancing ;)
