Version 3.06-TEST-3.1 (WORK IN PROGRESS BUILDS)
bomperstudio wrote:We have an issue as we can't use this test version as it needs cuda 8.0 and we're on Mac OS X 10.10.5 are there any builds that cover our cuda which is 7.5.30?
Are there any big advances in terms of speed and quality in this version compared to the latest stable version?
No you have to use Cuda8.0. Let's people answer this.
rwalker
Adaptive sampling alone is a huge improvement and worth making the OS upgrade, in my opinion. I understand you want to be careful about changing your OS when everything is working fine. I can report that MacOS 10.11.6 works fine and allows you to install CUDA 8. I did an installation on a second boot drive for testing, leaving my known-working drive untouched. I still have it in the machine, in fact, but I've been working in 10.11.6 for several days now and it has not been a problem.
Chrmez
This version is crashing constantly for me when rendering animations. Happens a few frames in. Stills and Liveviewer work fine.
Crashed 5-6 times in a row. I uninstalled the plugin and installed the latest stable version without rebooting (just to see if it was actually Octane that was causing this). And since then I have not had a single crash.
Latest macOS, latest C4D R18 version and the latest Nvidia drivers.
Bugreport:
https://www.dropbox.com/s/46hh6o4vhbizv ... t.zip?dl=0
C4D R18 / C4D R19
AMD Ryzen Threadripper 1950X — MSI X399 Gaming Pro Carbon
MSI 1080 Ti FE — 2 x PALIT 980 Ti Super Jetstream
Corsair AXi 1500W — Corsair Vengence 32GB 3000MHz LED White
Chrmez wrote:This version is crashing constantly for me when rendering animations. Happens a few frames in. Stills and Liveviewer work fine.
Bugreport:
can you give more details about scene or itself of scene? So we can check and find why happens.
Chrmez
Yes, sent you the scene in a PM
C4D R18 / C4D R19
Depaman
Hello.
C4D r18, with the last updates.
Also, CUDA and NVIDIA drivers are up to date.
MacOS 10.12.5
The plugin crash when start the live viewer. Only works 3.05
Clean scene, the live viewer start. When i move anything, crash the entire program.
Please help!
Hi Depaman,
what is your exact configuration?
Are you using eGPU solution?
If yes, please have a look at this other discussion:
viewtopic.php?f=98&t=61550#p315060
In short, there is an issue with R18.048, and it is necessary to go back to R18.039 to solve the eGPU incompatibility for now.
