OctaneRender® for ArchiCAD 3.03.3 [OBSOLETE]
I have updated the installers at the top of this thread with:
3.2.0.63
- Compiled with Octane 3.02
s3d-weyrauch
Small error: if I adjust the mid level of the displacement, than it occurs CUDA-error, and gives back silly values.
It works perfectly if I set it by an exact number manually.
This source doesn't contain any primitives!
Anyway, thanks for the features of Octane v3! And many many thanks for the floating license for the other developers as well!
David
BIM team leader
Win 10 | ArchiCAD GER 23-24 | Octane Plugin for ArchiCAD
13 Licenses | Network Render over 12 graphic cards
Scottiefeng
face_off wrote:I have updated the installers at the top of this thread with:
3.2.0.63
Hi Paul,
The Proxy editor stops doing real-time changes as previous version.
When you change the placement for translation, it does not happen to the viewport. You have to closed and editor and seer the result.
Scottie - the only time the plugin changes the position of the proxy is when Face Camera is enabled.
This will be fixed in the next release.
This thread is now for the STABLE version of the plugin. The TEST release of the plugin can now be obtained from viewtopic.php?f=56&t=55227 - pls subscribe to that thread.
I have updated the STABLE installer downloads at the top of this thread to release 3.3.3.66. Pls see the TEST thread for release notes.
This thread is now obsolete. Pls subscribe to viewtopic.php?f=56&t=55227 for STABLE release builds.
