Version 3.00 - Alpha10.1 (30.04.2016)
Hi CCIDgfx,
have you saved the octane windows in a layout?
If yes, try removing them all and save the layout, this should fix the issue, I guess :roll:
tomabobu
I've found that the ZDepth render pass is not saved while rendering an animation. Is shown in the LW but not saved when renderd in picture viewer.
Cinema4D R17 / Windows 7 on Intel i7-3930K / 32 GB Ram / GTX 670 / GTX 780 / 3 x GTX 970 on Amfeltech expansion cluster
tomabobu wrote:I've found that the ZDepth render pass is not saved while rendering an animation. Is shown in the LW but not saved when renderd in picture viewer.
Yes by some changes on buffers in sdk and adoptation to plugin. It's working on 2.25.
CCIDgfx
Got it working now but the time readout in LiveViewer is messed up
The progress bar is moving as fast as it should but there's no way it's going to take that long to render, lol
At least I hope not....
3D Motion Graphics Designer
Intel i9 13900K / 128gb DDR5 / 1 Nvidia 5090 FE / PSU EVGA 1600w / WIN 11
chupinsky27
CCIDgfx wrote:Got it working now but the time readout in LiveViewer is messed up
I have reported this same issue without a response before. Glad someone else sees this.
-Craig
C4D R17 | c4doctane v3 beta 2.1 | 2x980ti 2x780ti watercooled | Windows10 | 64GB ram
-Craig
It's fixed. Will be available for next releases.
JavierVerdugo
Hello,
render region is not working.
Render reduce the passes like it is doing a render region but render the whole scene instead.
So if you try to render region the 25% of the scene, it reduce to 1/4 of the total passes but render the whole scene.
Cheers
fuchsundvogel
JavierVerdugo wrote:Hello,
Cheers
viewtopic.php?f=33&t=52332
Known issues
Region rendering is still broken and we are working to bring it back as soon as possible. Unfortunately it requires a total rewrite due to the film buffer changes.
aaronsbot
Been loving trying the new Ocatane c4d 3.0
However here are some things that I feel need fixed.
-TFD Crashes quite often
-Volume scatter & Volume fog crash a lot as well
- In the 'Live viewer setting' I cant find any of the render passes. However they are in the normal octane render setting but when I render none of my info passes work.
Anyone having the same problems?
Thanks!
-Aaron
aaronsbot wrote:Been loving trying the new Ocatane c4d 3.0
Thanks!
-Aaron
Thanks. There is some problems about volumes in Octane sdk and a bug in tfd api. To post something about crash on volume scatter would be useful to understand where is problem.
Btw, you should see render passes in LV when you activate in render settings. You should select "enable" and a few passes.
