Which feature do you need the most?
Region Render
139
6%
Network render
85
4%
Render Passes
239
11%
Hair&Fur
286
13%
Particles
228
10%
Multilight
156
7%
Internal Texture Mapping (planar, box, spherical, cylindrical, camera and so on)
88
4%
Undo
104
5%
Volumetric: fire, smoke, clouds
369
16%
Mixing of daylight and HDRI environment
212
9%
Subdivision surfaces (OpenSubDiv)
80
4%
Multi UV channels
129
6%
Rounded edges
130
6%
Total votes: 2245
Evolutionary
The ability to select an object not to receive shadows would be useful.
AndreaMannori
Please consider the need of external gpus like these, Alienware & Sonnet.
http://www.hwupgrade.it/news/portatili/ ... 54681.html
http://www.sonnettech.com/product/thunderbolt/
I know that pci-e 16x is faster than Thunderbolt 1 or 2 BUT if Octane works with 4x or 8x pci... we can afford a little extra budget to increase the laptop power and continue using Octane vs any other engine.
THX
Andrea Mannori
win 8.1 x64; nvidia 770M driver 340.52; octane standalone 2 + c4doctane 2.
RahiSan
I dont know if this has already been mentioned, i would love to see a dedicated hair shader, something like vray hair. I know some people have created some pretty good looking hair, but I think the quality of vray hair has yet to be matched.
Also, is it only me or does displacement currently not work with procedurals? If so, this would be pretty useful aswell.
kavorka
RahiSan wrote: Also, is it only me or does displacement currently not work with procedurals? If so, this would be pretty useful aswell.
It doesn't work as of right now.
whersmy
@ AndreaMannori
using external gpus work very well with Octane. Even with expresscard 2.0 PE4L cards speed is perfect. I tested a gtx 750Ti with 0 problems.
As for the features
Multilight could really be a another game changer to get even more realistic renders, is it even possible to implement without considering speed decreasing due to simultaneously calculating light?
ML + octane speed and realism + Region render = instant win
Octane 2022.1.1 nv535.98
x201t - gtx580 - egpu ec
Seekerfinder
whersmy wrote:Multilight could really be a another game changer to get even more realistic renders, is it even possible to implement without considering speed decreasing due to simultaneously calculating light?
Yes!
Actually, there might be a twist regarding speed. Bearing in mind that I probably have no idea what I am talking about, consider the following for pure entertainment value... Octane performs poorly with small / few light sources. So perhaps, just perhaps, the 'master' render might actually be faster with ML. Imagine that.
Seeker
nuverian
Render Passes are a must for a production. If/when you do that also consider multi-channel EXR.
Volumetric Shaders is something I presonaly miss from the most rendering engines I try. Many renderers are great but they miss specialized shaders. Apart from usefulness, this will set Octane one step above those many renderers. If/when you implement those, please consider using widely used methods (rg OpenVBD) instead of going specific like Maya Fluid. I think it will be much better in the long term, considering the way the industry is moving.
Hair & Fur Prety much what's my opinion above. Specialized shaders are usualy missing from renderers. Again I think it would be much better if you make use of common splines found in any software instead of supporting specific systems. As a side effect this will also allow Octane to render splines.
Those are my 3 cents :)
Generaly speaking I'd like Octane to become more easy to use in projects and workflow other that still image product/archviz renders. To be more exact I have a hard time finding a nice workflow for CG/Live action integration & compositing.
http://www.nuverian.net
nuverian.deviantart.com
i7 920 2.66, 6G RAM, GTX 660 Ti, Win7 64x.
pBarrelas
Visibility control (diffuse, reflection, refraction and shadow ) at mesh level as in C4D compositing tag.
Win 8.1 Pro 64-bit| i7-4930k 3.4GHz | 32 Gb RAM | GTX 980 4Gb| Driver Version 344.75
NVN
Visibility control +++++++++100
we neeed that first of all!!!!
pBarrelas
Another feature that I'm missing after playing more with Octane, is a true material layering or stacking system. The current Mix material is limiative.
