OctaneRender 2020 for Modo [OBSOLETE]
I have updated the installers at the top of this thread with:
2020.2.0.166
- Fixed crash when selecting the Kernel->Animation tab
blockmind
Hello Paul,
Thanks for this fix. Now it resolved but still it doesn't save the animation frames.
Set timeline (for example) 0 to 3
Set max samples to a low value
Set Animation folder in animation tab
Click animate button to render the timeline
There is no file saved in the folder and after each frame octane error dialog box opens.
FileName::existsAsDirectory() can be called only on absolute file names
can't open '' for writing.
failed to save render
funk
Thanks for the quick crash fix Paul
2020.2.0.167
- Fixed bug preventing animation files from saving
funk
Thanks Paul.
By the way, you have the wrong dates on the release notes
blockmind
Thanks so much Paul,
I think the new save system doesn't save multiple render passes. I tried both "multi layer" and "multi layer discrete files" from animation tab, but it ends up with saving just currently activated render pass.
Am I missing something about this change note:
- Selecting the render pass from the Render Passes panel has been removed. Instead now use the Render Pass selection drop-down box on the Octane toolbar
blockmind wrote:Thanks so much Paul,
It looks like saving multi-layer EXR files is working, but not discrete layers to PNG files. I will fix this.
2020.2.0.168
- Fixed bug that was not allowing the saving of layers to discrete PNG files
Tharso
Octane dont work with Modo 15. I know it just came out, but it would be cool to test with the new Modo 15 =)
Modo15 uses a new set of Qt libraries, so I am working with Foundry to get the plugin working with these. In the meantime, I suggest sticky to Modo 14 when using the plugin.
Return to “Foundry Modo”
