OctaneRender® for ArchiCAD 3.03.3 [OBSOLETE]
I have refreshed the installers at the top of this thread with:
3.0.12.61
- Compiled with Octane 3 beta 1 (3.0.12)
- Fixed issue where render statistics were not being displayed when render region was enabled
Are you expecting the ArchiCAD plug-in to be released on the official Octane 3.0 release date?
It should be available either on the day, or within a day or two later. I suspect on release day you will be able to upgrade your Octane 2 license to Octane 3, and then continue to use the beta version of the plugin until the post-beta build is available.
Daniel_Ward
Hi Paul,
whenever you have a chance to get an AC19 plugin for Beta 2 would be appreciated. The Memory consumption bug in Beta 1 affected my 4Gb GPU's so much I had to got back to Alpha 10.
Cheers, Dan.
+MAP Architects, Christchurch - New Zealand
ArchiCAD 4.12 - ArchiCAD 24 || Octane for ArchiCAD
i7-7700K - Gigabyte Aorus Z270X Gaming 9 - 32Gb RAM - 3x Gigibyte GTX1070 G1 Gaming - Window 10 64Bit
Hi Dan. Beta 2 has some issues where saving images - so I think it would be a regression on Beta 1. I suggest you revert back to Alpha 10 if the memory consumption in Beta 1 is too high.
Daniel_Ward
Hi Paul,
how is Beta 3 behaving itself? :)
Cheers, Dan.
Beta 4 is due out today, so I will potentially post an ArchiCAD plugin with Beta 4 over the weekend and skip Beta 3.
3.0.15.61
- Compiled with Octane 3 beta 4 (3.0.15)
Daniel_Ward
Hi Paul,
do you have an idea of when you'll be able to recompile Octane for ArchiCAD 19 for the 3.0 release?
Cheers, Dan.
Should be today Dan.
Daniel_Ward
Hi Paul,
I'd better get my Licence upgraded then!
Cheers, Dan.
I have updated the installers at the top of this thread with:
3.0.20.62
- Compiled with Octane 3.00 (3.0.20)
- Fixed issue where loading a pla/pln with corrupted Octane data would cause ArchiCAD to crash
- If you have ticked "Use offline licensing on this computer" when authenticating the plugin, you can now click the Deactive button on the OctaneLive tab to de-activate the plugin license
You will need an Octane 3.0 license in order to use this version of the plugin.
