About C4D R10: "I'm not sure about this support. This is not a matter of finding a solution. Need lot of tweaking and time spending on our code for this."
Does this problem relate to R11.5 as well?
Testing Beta 0.87b (SDK 1.20) **updated 04.10**
11.5 can be possible, it's much easier than r10.TonyBoy wrote:About C4D R10: "I'm not sure about this support. This is not a matter of finding a solution. Need lot of tweaking and time spending on our code for this."
Hi people,
this unstable messages that is really irritating me. I'm thinking 0.87b and newer's are really stabile. Because there is some serious fixes. Main structure of plugin was shaped. Also we did lot of tests in production environment. Are you sure that your problems are'nt related some other plugins? or wrong files on installation? I don't want to give names but some plugins has problems.
Also i'm curious about what gui features prevents to release a finale version? Do you want to open a thread to write down suggestions?
thanks, this is supporting my suggestion. When i used some plugins, i'm getting weird crashes.cyartist wrote:Hi Ahmet,
I have not had any crashes so far very stable with latest version no render hanging. I am using R13.
Let me know when it is ready for r15 and will test it out.
Regards
Gary
And a screenshot from last version with sub-frame motion blur support
Aoktar - thank you for short info about c4d plugin for c4d R10. Now i know that is no chance for me to use live version Otane in any way. But my hope will never die.
Win 7 64 bit, i7-970 OC to 3.9 Ghz, GTX580 3GB + GTX560 Ti 2GB, 18 GB Ram
do you have stability problem with turbFD? I'm aware only a startup problem with that.Sc4rfy wrote:The main problem for me is with turbulence plugin, there is a solution in future for make octane/turbulence run togheter? Sorry for bad eng
Yes, with turbFD and octane (last release) cinema crash immediately, if i remove turbulence octane runs fine.aoktar wrote:do you have stability problem with turbFD? I'm aware only a startup problem with that.Sc4rfy wrote:The main problem for me is with turbulence plugin, there is a solution in future for make octane/turbulence run togheter? Sorry for bad eng
My question was if there is a solution for this problem in future?
Win 10 64 Bit | i7 930 | 12 Gb Ram | GTX 760 |
turbulencefd blocks our dll loding functions. apply this solution:Sc4rfy wrote:Yes, with turbFD and octane (last release) cinema crash immediately, if i remove turbulence octane runs fine.aoktar wrote:do you have stability problem with turbFD? I'm aware only a startup problem with that.Sc4rfy wrote:The main problem for me is with turbulence plugin, there is a solution in future for make octane/turbulence run togheter? Sorry for bad eng
http://render.otoy.com/manuals/Cinema4D/?page_id=651
