Version 3.06.2 - obsolete stable
VVG wrote:
Idonee wrote:Hello, can some one tell does c4d objects like "background" and "foreground" works in Octane? I think i saw them in a few tutorials and in manual, but when i tested latest 3-4 versions - it doesn't seems to work. If it should not - then fine, but in another case it have an issue. Thanks for your attention.
ps. I’m using Cinema 4D R18.048. Sorry about my poor English.
I always very often get an error when I do an LV update.
Sample scene attach.
It's a message when shader samples have an error while trying to initialise C4D shaders. You have a C4D gradient in background. Btw It's working fine. Are you on OSX? Can you see gradient rendered?
Remo wrote: Anyway....recently I noticed a bug by using the new filtering options in the displacement node. C4D seems to totally freeze down when Im using the Gaussian type and hit render! No issues with the box type at all!
Not sure if you are already aware of this issue...:)
But I hope it helps to mention it!
I can't see any issue with that. Could you please send me a sample scene for reproducing that?
VVG
Win10 x64
but
I can not get an error again in the last time)) works like a good thing
Support for infinite planes (STD 3.06)
when in C4D?
thank you
Win 10x64, AMD 1950x 16C/32T, RAM 32Gb, RTX 3060x3
Octane-for-C4D(R23.110)2021.x.x, Cycles4D, Centileo. Nvidia 472.47 STUDIO
Download links has been updated with latest version(3.06.2). Enjoy it!
rwalker
aoktar wrote:Download links has been updated with latest version(3.06.2). Enjoy it!
Download link for MacOS is incorrect?
Yes appearently. I've replaced with correct link, sorry for that!
aimning
Great, thanks
cyrillweiss
Hi aoktar
Had an issue with the Live DB Viewer in R18.048.
I've set the local DB path to an existing folder with materials, but it didn't show me the categories of the local DB, only when I created a new category the existing ones where showed. And I couldn't delete the created category, had to do it manually in Windows Explorer, but unfortunately Cinema crashed after that :(
It also seems, that when I rename the material in the Live DB Viewer, the orbx file gets renamed, but the viewer still shows the old name.
Cyrill
HW01:WIN10x64/X79/i7-3930K/64gb/GPU:1xTitan X, GTX 1080ti, SW:Maya2018/2019, Cinema 4D R20
HW02:WIN10x64/Z370/i7-8700K/64gb/GPU:1xTitan X, GTX 1080ti SW:Maya2018/2019, Cinema 4D R20
etc. ...
DinoMuhic
BUG:
Clicking on the "Noise" button in the IPR in the bottom left corner when using a baking camera leads to a driver crash.
abstrax
DinoMuhic wrote:BUG:
Thanks for the bug report. We fixed the issue in 3.06.4.
