OctaneRender for Modo 3.03.3 [STABLE]
If I'm not completely mistaken, I remember reading that you were going to implement Modos native fur to render in Octane at some point.
Is that still something you have in your pipeline? I'm using the workaround by freezing the fur into geometry, but would love to be able to use the Modos fur controls instead, would make things alot easier at times.
Yes - I already have a build of this working, but there are still some issues to address, so it will be some time before it is released in the TEST build. But it works very nicely. You will love it!
sgtprobe
face_off wrote:Yes - I already have a build of this working, but there are still some issues to address, so it will be some time before it is released in the TEST build. But it works very nicely. You will love it!
Wow, thanks for your answer. Do you have an ETA, or am I pushing it too far now? :P
Cheers!
/Jonas
Platform: Asus X99-E WS CPU: 5960X GPU: 2 x GTX Titan Black, 980ti Software: Modo, Octane for Modo, Win 10 Pro
Hi Jonas - I can't provide an ETA at this stage - sorry. The change is part of a much larger change - which is going to take time to get running smoothly.
I have refreshed the installer at the top of this thread with:
2.22.2.60
- Compiled with Octane 2.22.2. See Octane Standalone release notes for details
- Addition and modification of stereo and panoramic camera pins to match Octane Standalone
- Added support for multiple (up to 3) UV maps when loading meshes with the Load Cage property ticked.
- Added Thin Lens camera Pixel and Aperture Aspect Ratio pins from Octane 2.22
- Fixed Icon thumbnail colors when saving an Octane material as a preset
- Added option to move the Environment IBL up/down (new pin "IBL Y Translate")
- Changes to the Kit CFG to compatibility with future releases of Modo
cuffi
face_off wrote:Yes, I am revamping the whole UI and Viewport at the moment. I will see what can be done.
Hey Paul,
if you need some assistance with Icon or design again...let me know!
René
Win 7 Ultimate 64 Bit | GTX780 Ti | GTX 560 TI | Driver Version 337.88 | Intel Core i7 3930K 6x 3,2 GHz | 32 GB RAM
Web: http://www.mentalarts.com
Thanks René.
Some users may have noticed the Modo 801 SP4 release notes at http://community.thefoundry.co.uk/suppo ... tails.aspx includes the following:
SDK: Adds the Rendercache API (beta implementation), allowing SDK developers to access the same rendering data as the internal MODO renderer, exposing the geometry cache and shading information.
This is really an incredibly important change for OctaneRender for Modo users, in that it will allow the plugin to extract geometry directly from what you see in the OpenGl viewport, rather than having to iterate through all the mesh, instance and replicator items in the scene. The Rendercache API allows rendering of geometry from the Fur Shader, and hopefully proxy meshes (untested), which are not currently supported by the plugin. I have a version of the plugin built with the Rendercache API, and the Fur Shader rendering is great. I haven't had time yet to test the proxy mesh rendering. I'm am hopeful that vertex motion blur will also be supported by the Rendercache API in the future. So in summary, a big thank you to the Modo devs for making this available, and there should be a build of the OctaneRender for Modo plugin which works on the new Rendercache shortly (it will however need a later version of Modo than Modo801SP4, since the initial release of the Rendercache is not stable enough for the Octane plugin).
I will post test renders on a new thread I will start in the Modo forum here in the next week.
riggles
Great. Thanks Paul. I was happy to see that addition to the SP4 release notes as well. Perhaps this would also add support for more particle uses, such as particle generators on displaced surfaces? It'll be interesting to see what this really makes possible. Look forward to your tests in the MODO forum. But you're saying it won't really be usable until 801 SP5 (if there is one) or MODO 901?
That is correct.
2.22.2.66
- Fixed issues with the downloadLiveDb command (and refreshed the downloads in the on-line Manual)
- Fixed issue where Octane IES lights where not pointing in the same direction as the Modo Photometric light that was used to create then
- Photometric lights now convert (via Create Octane Emitter) to geometry which is invisible in the Octane scene
- Fixed issues when multi-selecting Modo lights and then clicking Create Octane Emitter
- Fixed Kernel Save Format combobox hints
- Cleaned up properties displayed when switching between Thin Lens and Panoramic cameras
- Removed Environment max samples pin
- Added Light Pass Id to the Viewport render passes
- Added support for additional control points in the Octane Gradient node. Use the Gradient 2 node and click Edit Gradient to access this.
v1adut
Hi Paul, quick question,
How I should correct make octane render interpret normal maps ?
Do I have to see the gamma to 1,0 or to 2.2.
I am asking this because I am confused, since the value should be linear, yet the image must be colored in order to get the rgb from the normal map.
Second question, how roughness is interpreted by the octane render engine, ... is black 0 roughness, and white 100%, or black is 100%, and white 0 roughness.
I am asking order to insert the info from substance painter to octane render as correct as possible.
Return to “Foundry Modo”
