Octane Render 2.0 for Cinema 4D previews
Sub forum for help and tutorials.
prodviz
Looks very cool.
Are you using hair in that technique?
DayDreamer
Hello everybody, I'm very confused with the Particle Engine inside of c4d's octane. Can somebody tell me where to find some info about it and how do i use it?
CPU: 5930K i7, GPU: 2x iChill Nvidia 780Ti, 980, RAM:32GB, Win 7, SSD.
useruser
hi daydreamer,
if particle engine is enabeld you are able to render xparticles "on the fly" for example. each partilce will be renderd as a sphere. you can adjust the size and colour of the spheres directly in the the xparticle-emitter settings under visibility-tag if i remember right.
btw.
here a quick vertex-motionblurtest
https://vimeo.com/99474697
rendertime was only 30 seconds on a titan/gtx780 rig. DR-diffuse. the motionblur-calculation is so incredibble fast! octane 2.0 is just amazing! thank you ahmet! :)
Workstation: Win 10 PRO 64 bit, 3,4 GHZ ,6-cores, 64 GB RAM , 4x RTX 2080 Ti
1. RenderSlave: Win 10 Pro 64 bit , 3x GTX 980Ti
2. RenderSlave: Win 10 Pro 64 bit 2x GTX 980 Ti
useruser wrote:hi daydreamer,
btw.
thanks to you. Next step will be more shapes on XP. We can use display shapes.
ten
Ahmet, Do you think we will ever be able to use the XP shaders with Octane, or is this just not possible?
ten
( PC ) i7 5960x octal 4.5ghz / 64GB / 2x Titan X 12GB / 1x 780 6GB - ( Laptop ) i7 4790k 4ghz / 32GB / 980M 8GB - Octane CD4 2.x / C4DR16.x / win 8.x
Gwrath
I cannot for the life of me get x-particles to render in octane. I can only get native emitters to render in cinema, and only as white balls.
What settings must be enabled for the x-particles emitter to render in cinema?
Thanks for the help.
Return to “Help / Tutorials”
