Version 3.05.3 (13.01.2017)
Chromfell
aoktar wrote:
Which material?
I tested it with glossy and mixers and it always stopped responding. I don't think it was caused by any material in particular.
I just started using LocalDB instead, works much better :) I suggest anyone who has this problem should aswell!
Windows 10 Pro -- RTX 2070 x 3 -- Ryzen 1920X, 32GB -- Blender, Standalone, Cinema4D
Oleg
Hey, I got a problem with Light Shadows and Light BlackShadows passes (see the pictures below). Same problem with some other passes like refraction filter for example
Hi Oleg,
please, have a look at this discussion about the same issue:
viewtopic.php?f=30&t=56386&p=301299&hil ... ss#p289812
I guess you only need to change the position of the beauty pass.
Oleg
bepeg4d wrote:Hi Oleg,
Wow, thanks! Looks like a test for attentiveness — all these dots are outside pass itself. Now you should put the shadow pass underneath the beauty pass... Thank you Octane for keeping us in shape
jeffbriant
I'm having an issue with Octane Scatter. When I put a map into the Shader area, it's acting like it's stretched. I've tried a c4d noise shader, png's, jpgs, image texture nodes, nothing works.
2x1080's network rendering to 4x980Ti's
jeffbriant wrote:I'm having an issue with Octane Scatter. When I put a map into the Shader area, it's acting like it's stretched. I've tried a c4d noise shader, png's, jpgs, image texture nodes, nothing works.
[/img]
Could you pls try with 3.06-test3. I've left 3.05.3.
alien
- Vertex weights support for Houdini Engine objects
Any sample how it works?
I imported Simulated Mesh via HDA* . Vertex map Works if I move mesh out of HDA null and Press "C" convert it to static mesh . But vertex maps don't work properly under HDA live mesh.
*Houdini Digital Asset
jalejune
Where can I find the Slave Install script for a Mac that has a eGPU Titan X? My work station has a licensed copy of Octane. Do I need another license for the slave?
Hi jalejune,
the daemon installer script is in the Standalone .dmg installer:
https://render.otoy.com/customerdownloa ... _macos.dmg
But you always need a Standalone license for each Slave, otherwise the daemon cannot be activated.
Tag12345
If anyone could check out my post on the other thread version 3.6 test 4, can I get a response.
This thread seems a bit more active
