Version 2.24.1-R3 (06.10.2015) - obsolete stable
momade
eightvfx wrote:hello Aoktar !
thanks for all the work you are doing !
to continue on what was saying desire : " Hi, aoktar! May I ask you about masks? Do you plan to improve masks' accuracy? "
when you say it's not pluggin related... do you think in release 3 > it s something that will be improved ?
thanks.
PS> about this release 3... any date in view ? ;))
thanks again!
If you only need one mask: The render layer option of octane produces flawless masks. but only for one object channel at a time...
desire
momade wrote: If you only need one mask: The render layer option of octane produces flawless masks. but only for one object channel at a time...
And exactly at this point the problem is =)
To make several masks (that would have perfect matching) from one scene view, you need to re-render the view again and again ))
momade
Anybody else issuing that octene material are dublicating at random in material editor. i have to remove all unused materials fromt ime to time...
miohn
Hi momade,
thats right. Here as well.
I got lots of double materials in my scene and I have been wondering all the time, why or
how I copied an object (and therefore also the materials) so many times inadvertently into my scene.
I would not have thought, that Octane is doing this until your post.
regards
Mike
momade
miohn wrote:Hi momade,
regards
Mike
so im not alone.
aoktar: can you look into this?
momade wrote:Anybody else issuing that octene material are dublicating at random in material editor. i have to remove all unused materials fromt ime to time...
would be great to give more info. How, when, after which operation? Are you sure that's not a user mistake? I haven't notified it before. Has this started after last version with mix material improvements?
Huv
Hi, is there a trick to get a single shadow pass on an archiviz projet ?
I've tried to follow these tutorial (http://inlifethrill.com/trainings/multi ... cinema-4d/,
but no way to obtain the single shadow passe needed...
Missing something ?
Thanks for your help ;-)
garytyler
I'm having the duplicating material issue as well. I'm not sure why it happens but it happens with the first few materials in the list. They get duplicated. I'm suspicious that it's related to saving the same project with different names. I often save updated versions of a scene with an appended number in the filename. Maybe that's when the duplication happens?
Also, Live DB is too slow to be useable for me right now. I've tested my internet connection speed. I'm on Windows 8.1 and R16 with this most recent version.
Win 8.1 / C4D R16 / Maya '16 / 5x GTX 980 Ti
momade
Yes I also save incremental numbers and the dublicated materials are also the ones in the beginning of the material list. i will observe this further.
Chriz
garytyler wrote: Also, Live DB is too slow to be useable for me right now. I've tested my internet connection speed.
For me the same: Live DB got very slow since update on 2.24.1. R1, running on Win 7, R17. It takes minutes to load the previewimages and my internetconnection is really fast.
Have a nice day, Chriz
http://www.C9W.de - Win10 - Dual E5 2620v3 - Display 1 GTX 1080 / Render 1 3090 RTX - 96 RAM - C4D MSA - C4D Plugin version: current - Standalone: current
