OctaneRender™ 2.1 for LightWave™ - Daily builds
juanjgon
BorisGoreta wrote:When having octane box light in the scene I can't make it hidden in the OpenGl viewport to make animation previews.
This problem is fixed for the next release.
MrFurious
Juanjo I think I found a small bug in the latest build. Actually there are two, one crashes Lightwave and the other seems to not be working properly.
LW Crash bug: open a new scene, ad an object (any object, even a default box) Add an Octane material to this object (diffuse, spec, or glossy). Then connect the octane material to the LW material node USING THE RIGHT CLICK --> NODE MENU --> LINK TO SURFACE method. Lightwave crashes every time IF the Octane plugin isn't enabled.
Also, 'Get T Texture Layers' placed any transparency map into the Normal input, rather than the Opacity input. This issue only seems to be prevalent for DIFFUSE materials. Glossy works fine, but Specular ignored the colour texture, and places the transparency channel into the 'transmission' input by default.
Dino Inglese
CG Artist
Melbourne Australia
Octane build 4.04.0.145
juanjgon
The context menus can't work without the plugin enabled, but the crash is fixed now. Also the link problem in the diffuse material is fixed.
Thanks for reporting this issues.
atnreg
Thank you very much again :)
Is it possible to control the location where the automatically added nodes appear in node editor? They often go very far out of view and so pressing A,F is the only way to get them into sight. It may be that you can't adjust the location from the plugin but if you can, please make them appear near the node the menu was called :)
Thank you again!
Antti
AMD Ryzen Threadripper 2990wx (32c/64t),64GB RAM,NVIDIA GTX 1080ti,Win10
Clarisse 4,Houdini 18 (+Octane 2019),Blender2.81,Fusion360,Onyx,ZBrush,SubstPnt...
Started: Houdini 2019, Clarisse 2016
No business, just fun :)
BorisGoreta
Context menu in node editor crash LW 1012.
Pressing RMB on Diffuse input of Octane Diffuse Material
Load Image does not work in Octane Texture Image node
MrFurious
juanjgon wrote:The context menus can't work without the plugin enabled, but the crash is fixed now. Also the link problem in the diffuse material is fixed.
Thanks mate. I realise the crash bug shouldn't really occur under normal usage. Cheers.
Dino Inglese
CG Artist
Melbourne Australia
juanjgon
atnreg wrote:Thank you very much again :)
Thank you again!
Antti
It is not possible because the LW SDK doesn't have a function to get the nodes position in the node editor, so I can't know where to place the new nodes near the existing ones.
juanjgon
BorisGoreta wrote:Context menu in node editor crash LW 1012.
Do you have the Octane plugin enabled? ... this functions don't work if you don't have the plugin enabled, and the context menu crash if Octane is not enabled is fixed now for the next release.
atnreg
juanjgon wrote: It is not possible because the LW SDK doesn't have a function to get the nodes position in the node editor, so I can't know where to place the new nodes near the existing ones.
Ok, that's what I thought but wanted to be sure, thanks :)
Antti
BorisGoreta
This could be what actually happened because now it all works as expected.
Return to “Lightwave 3D”
