Beta 2.2 RC1: Maya exporter plugin (unofficial)
cgbeige
bazuka wrote:- hm, should not hang, only while the obj is exported... i dont have that probl here
It might be a problem with Mac Maya 2011 and Qt - it does a stupid thing where the palette windows float above other apps during renders. But the whole app not being usable is weird. Is it waiting for a returning image?
bazuka wrote:-- dont know about this one, i dont think its the probl with script, can u check the output line from maya?
What am I supposed to put in the GPU devices to use field? Using this command in the command line renderer works when using both GPUs:
octane -g 0 -g 1 /path/to/scene.ocs
but if I put "0,1" or "0-1" in the GPU devices field, it crashes Octane.
face
with spaces between...
face
http://vimeo.com/user2509578
bazuka
@cgbeige
no its not waiting, u should be able to do anything, u can check on the 1st page im uploading some videos how to, but this is under windows, dont know if there is a probl with osx
u can put even without spaces script will understand, just dont use dots, commas or similar things
p.s. let me know what would u like me to add in settings to be saved...
Maya 2009 x64 & Maya 2011 x64
Windows 7 x64 & Windows XP x64
2x Quad Core Q6600, 8gb, Nvidia Gtx 260 & Gtx 460
serbos
Hi bazuka,
I got my license today and started experimenting with Octane. I am very excited from what I see so far.
I encountered mismatch between the Maya Camera and the output from the Octane camera. I did a little digging around in the mel script that helps in the exporting and came across some things that I attempted to improve. Please see attached mel script (it's for Maya 2010).
a. I added a snippet to help the user navigate less when setting the "ProjectPath"
b. I took into consideration the camera's horizontalFilmAperture in the calculation that you already had there to come up with a correct field of view. Now the render between Maya and Octane match almost exactly.
There is a pixel or maybe half offset. I don't think that is a mel script problem. I think that the developers of Octane need to address and make it match exactly. It's a great tool. But if it doesn't match exactly it is going to become an obstacle in production.
c. During my tests I exported things from Maya and ended up with more than what I wanted. Things that were invisible in Maya showed up in the Ocatane render. Things such as blend targets etc. I modified the OBJ export to export only selected objects. Animated visibility is another issue. Since the obj format does not support visibility I wonder if it is a good idea to go through the OBJ format in the first place. I would hope that a C++ conversion be developed at some point in the Octane format. Even if it means that users have to get the new plugin every time a new version of Maya comes out.
Anyway. I look forward to seeing Octane develop further and wish to help in any way that I can. It is very very promising.
serbos_maya2octane.zip
(6.55 KiB) Downloaded 276 times
bazuka
@serbos
hi my friend ;)
there is no mismatch, i just didnt warn the people that the focal depth is actually the maya's focal lenght and the real focal depth is calculating in the script...
i left it like this coz it was easier to understand coz as we all know no1 uses the focal depth in maya ;)
yea i notice that obj exporter from maya exports everything even the hidden obj and visibility probl too
if u ask me best way is to make real exporter for octane, something like other standalone renders have, (mw, fry, etc...)
cheers
p.s. i have checked the script and u didnt dl the latest ver ;) i made some changes, maybe thats why u have mismatch in octane...
also its not smart to export only selected obj, what will happen if u have 1000 or even more obj in the scene? u will have to select the 1by1 and the export them? ;)
face
bazuka wrote:@serbos
Mabye it gives in Maya the chance to check with a script, which objects are visible.
With that information, you can run your script, select via script only the visibles and then export them.
face
serbos
Hi again.
You are correct. The camera does match with the newer version of the script.
But it's still off by something like a pixel... Are you not seeing it in your tests?
I'll try it again with a fresh simple scene. Maybe there's some other variable in the mix.
Thank you.
serbos
Hi Bazuka,
Here's a zip file (see attachment) with a Maya scene and an Octane scene generated from it.
I rendered an image from both programs and made a multi-layered tiff from the result. If you zoom in and toggle the top layer (or do a diff) you can see that they are off by a couple of pixels. Please let me know your thoughts. Are other programs having the same issue? XSI? Blender? Or am I doing something wrong?
Thank you.
compare.zip
(248.9 KiB) Downloaded 276 times
bazuka
yea ur right, but u couldnt see that if u didnt put side by side images ;)
im not sure where is the probl i think maybe in position of camera and precision of xyz values but will see time will tell ;)
@face
its possible to check every obj but like i said what if u have >10000 obj that will take some time to check and export
ill do some test and check the speed, if its less then 1sec i could implement it...
going to sleep, see ya
serbos
[quote="bazuka"]yea ur right, but u couldnt see that if u didnt put side by side images ;)/quote]
If you do a composit to add some extra effects to the octane render it will be an issue. Or if you use a mat generated from Maya to lift something from the Octane render you will end up with a halo. Can you convey this to the developers?
Good night. Thanks for the discussion.
Return to “Autodesk Maya”
