Cinema4D version 2023.1.2-[R7] (Obsolete stable) 27.03.2024
desire
aoktar wrote: You may see that need 2024.3.2 when you read requirements
ouh, sorry
frankmci wrote:
aoktar wrote:R7 build is out with some fixes/improvements. Enjoy it!
viewtopic.php?f=85&t=82847
Thanks for the requested Texture Manager features, Ahmet. Much appreciated! This will make cleanup/optimization a lot easier.
Great that you loved, spent a few days to improve it. Enjoy it!
1026613912
I’m very curious when the official version of oc2024 will be available, and I’m looking forward to it.
snahbah
The 1,2,3 nav in Liveview might some like a small change but it's HUGE for me and my workflow.
Unfortunatly the keys do not match the C4D mappings:
R7: 1 = Rotate, 2 = Move, 3 = Zoom
C4D: 1 = Move, 2 = Zoom, 3 = Rotate
If they could match C4D's keys that would be really appreciated :)
Also, although you can add every other material in the LiveViewer, the Standard marterial is missing from the list for some reason.
And wanted to swing by and say "thank you" for all the hard work.
snahbah wrote:The 1,2,3 nav in Liveview might some like a small change but it's HUGE for me and my workflow.
Thanks a lot! Sorry for wrong combi, I've fixed it on latest moment build. Please re-download and use it!
Btw I have Standard Surface commands in Live Viewer and Node editor. Could you please show where you can't find it?
Composite texture's connection type is broken, I'll update the R7 without changing the version name. I'll write it soon when ready.
I've updated the links with fixed R7, re-download/install it again if you got the build before this message moment. Sorry for trouble!
SSmolak
Thank you for updates ! This would be great too :
Anlv
SSmolak wrote:Thank you for updates ! This would be great too :
The attachment gradient.jpg is no longer available
After discovering your reply, I immediately proceeded with the update (R7). Unfortunately, I couldn't find the octane gradient. I don't know why. Can you please let me know which version you are using? :?:
3D Motion Graphics Designer / E-commerce Designer
13700K / 64GB / 4090 / PSU 1250W
SSmolak
Anlv wrote: Unfortunately, I couldn't find the octane gradient.
Ha, this is why I said "would be great" to see Octane Gradient in that menu too :) Feature request
eyeonestudio
Octane Not Loading My Notebooke(eGPU 3090)
R6 is OK.
C4D console.....
CRITICAL: Method net.maxon.interface.assetlink.Create@874ec4c6e3a0aae not implemented by AssetLinkImpl (requested by file:///C:/Program Files/MAXON/CINEMA 4D 2024.2.0/plugins/c4doctane/c4dOctane-R2024.xdl64). [object_impl.cpp(908)] [objectbase1.hxx(537)]
net.maxon.asset.framework: Initialization of net.maxon.interface.assetlink [interface] failed.
CRITICAL: Method net.maxon.node.interface.nodeslib.CreateTemplateFromNodeSystem@3e4a2e59c095eb1a not implemented by NodesLibImpl (requested by file:///C:/Program Files/MAXON/CINEMA 4D 2024.2.0/plugins/c4doctane/c4dOctane-R2024.xdl64). [object_impl.cpp(908)] [objectbase1.hxx(537)]
net.maxon.nodes.framework: Initialization of net.maxon.node.interface.nodeslib [interface] failed.
Drawport API initialized
Framework : DirectX
Vendor : NVIDIA
Device : NVIDIA GeForce RTX 3090
Framework version: 12
WIN10 21H1 19043.1165
Processor Intel(R) Core(TM) i7-8750H CPU @ 2.20GHz 2.20 GHz
Installed RAM 32.0 GB (31.9 GB usable)
