OCTANE BENCHMARK: Submit performance scores for your rig!
igen
FrankPooleFloating wrote:igen -- would it not make more sense to list them in order of Pathtracing, rather than cores?... and perhaps divide 600/Kepler series cores by 3 (and call attention to this at top - that the Keplers are tweaked to reflect Fermi cores)?
That not perfect data, to many various data such as different octane version, fermi and kepler, single and multi gpu.
rendercamp
virtual photography & 3d animation
asus maximus extreme VI :: i7 3770k :: 16 Gb Ram :: 4 GTX 690 4 Gb :: win7 64 bit
r-username
I noticed someone on the list is using 500 series and 600 series cards together, I thought this was something to be avoided?
I have a 590, so can I go out and pick up a 680 or 690 now?
Thanks in advance.
i7 960 - W7x64 - 12 GB - 2x GTX 780ti
http://www.startsimple.com/ - http://www.gigavr.com/
whersmy
It`s no problem, amazing program.
Performance difference between a 590 and 690 won`t be a lot still.
Octane 2022.1.1 nv535.98
x201t - gtx580 - egpu ec
igen
here i make simple list between 580-680 with single and multi gpu ...... :?
rendercamp
whersmy
I get 8.65ms with 4x 580`s on octane v1.02. :|
kavorka
whersmy wrote:I get 8.65ms with 4x 580`s on octane v1.02. :|
are you sure you have all 4 activated in the properties panel?
whersmy
Yes, it regs 4 gpus. Disabled alpha shadows (forgot first time...), now I`m getting 9.55ms PT on v1.02.
According to the table I should be getting around 16ms right?
http://render.otoy.com/forum/download/f ... &mode=view
whersmy
Disabled the sli connector that connected 2x 580s, now I`m fine: 16.24ms!
I had SLI off in the control panel though, seems the connector disables 2 580`s?
So final: 16.24ms with 580s (4) v1.02.
810/2095 clocks = 17.02ms
845/2136 = 17.47ms
cfrank78
You have filled in wrong numbers from me. I never had a 580 in my Computer! Here again i put the results of my 2 rigs! Hope you fill in my numbers right this time:
Computer 1: 1:Zotac GTX 570 OC : 3.56
2:Gigabyte GTX 670 Windforce OC: 3,42 normal OC Profile and 3,67 extreme OC Profile
Combined1: 7.23
Computer2: 1: MSI GTX 660 TI Power Edition: 2.27 and extreme profile 2.56
2: Gigabyte GTX 670 Windforce OC: 3,42 normal OC Profile and 3,67 extreme OC Profile
Combined 2: normal: 5,69 and OC extreme 6,23
Allways used PT and alpha shadows off. Nothing else changed in the default download zip.
Used on both machines 1.02
Rest of my Hardware you can see in my signature! Hope this times i made it clear!
Kind regards Chris!
leblanc980
Finally found a PCI express 2.0 extender cable on amazon for 5 bucks. So I was finally able to get all three GPU's going on my 730watt power supply lol.
The EVGA GTS 450 maxed out at 0.98 ms/sec.
cfrank78, what overclock settings you running on that GTX 670 to get 3.67???
