Version 3.06.2 - obsolete stable
momade
Disable hair render in vpost effects. Or send me your scene if you still need some help.
What are vpost effects?
jblessing
Hello, when we upgraded to 3.06 across all of our machines, our network renders no longer render at full speed. They show 98% usage, but they are only running at around 400mhz instead of the previous/normal 1400mhz. Is there something that isn't forcing a high priority on these?
Win 8.1 | 4.1ghz 5960x | Cinema 4D R20 / 3ds Max 2018 | 2 x Titan Z + 980
Win 10 | 3.0ghz 2697 v3 | Cinema 4D R20 / 3ds Max 2018 | 4 x 980ti hydros
4 x Win 7 | 4.0ghz 5930k | 4 x Titan Black or 4 x 980ti
kyr
Hi Guys
what about the motion blur in the Panoramic Camera (Version 3.06)? It´s not working right? Or i'm missing something?
kyr wrote:Hi Guys
It's a bug for current SDK. It will be fine with 3.06.1 release.
see this post: viewtopic.php?f=30&t=61421&p=314155#p314155
momade
Ok, got it. Thank you aoktar.
Hi everyone,
I've updated uploads with latest build 3.06.1. Don't forget to update your standalone too if you need to use it. Enjoy it!
jblessing
jblessing wrote:Hello, when we upgraded to 3.06 across all of our machines, our network renders no longer render at full speed. They show 98% usage, but they are only running at around 400mhz instead of the previous/normal 1400mhz. Is there something that isn't forcing a high priority on these?
Turns out I hadn't rebooted these machines since upgrading to 3.06 from 3.05. I just did and it fixed the GPU speed problem.
Idonee
Hello, can some one tell does c4d objects like "background" and "foreground" works in Octane? I think i saw them in a few tutorials and in manual, but when i tested latest 3-4 versions - it doesn't seems to work. If it should not - then fine, but in another case it have an issue. Thanks for your attention.
ps. I’m using Cinema 4D R18.048. Sorry about my poor English.
Kretschi
aoktar wrote:Hi everyone,
Wow, great!
Thanks!
