OctaneRender for Modo 3.03.3 [STABLE]
A video on the 2.20 and 2.21 features.
[vimeo]http://www.vimeo.com/119302514[/vimeo]
Dmi3ryd
Paul many thanks for new release and amazing video. I finally figured out how to use render layer passes.
Only one thing I can not understand why to see render layer passes we need to activate alpha channel?
Win 8.1/64 | Geforce GTX780TI | Core I7 970 | 24GB
Hi Dmitry - some of the shadow passes are alpha channel only - so need the Kernel Alpha Channel enable to render correctly.
Dmi3ryd
Now i understand why. Ok thanks! :)
Tharso
Hi Paul,
How can I stop refreshing octane material message, all the time?
Tkss
Hi - I'm not quite sure what msg you are referring to - can you post a screenshot pls? Is it happening on all scenes - or just some?
Tharso
When I start a clean scene, Idont get this message but when I bring some models it happens always when I do some material changes. I dont understant at all, with modo materials it happens and when I add octane override material it stop. With my dual xeon it is laggier then an old 3930k.. its drive me crazy =).. sry my english
How long does it take to refresh pls? If you just change a pin value (like changing a color or a value) is it showing the refresh? Would it be possible to send me a scene where this happens, so I can take a closer look?
Tharso
I will send to you the file.
Tharso
Hi Paul,
When I have Hdr in texture environment and modo material I get that long refreshing octane material, but with sunlight I dont get refreshing octane material. Sometimes with texture environment and octane override material it dont happens, than I think that it is not because the large scene and I have 2 gtx 980.
is that normal?
thanks
Return to “Foundry Modo”
