Version 3.08.1-R4 (obsolete stable)
Nando_The_Fly_Design wrote:Aoktar thank you for the great job. I take this opportunity to share new icons of the materials blend, mix, metal, glossy and toon. This makes it easier to find them on the material bar.
Just replace the files in the folder: C:\Program Files\MAXON\CINEMA 4D R18\plugins\c4doctane\res
Greetings!
ICONOS FM octane.rar
Many thanks! Most likely I'll use them for next release. Greetings!
artdude12
aoktar wrote:Hi all,
Here's i'm sharing the new wip manual. It's still under heavy construction. I believe that will be very useful by completed parts.
NEW C4D OCTANE MANUAL IN FORM OF DRAFT
Looking great and very helpful!
i7 4930K_Asus_RampageIV-Extreme_64GB_3-Titan_NVIDIA-337.88_Win7-64
alexchopjian
Ahmet, this is seriously awesome. Greatly appreciated!!!! So excited to read through this! :D
y81r
Greetings!
Awesome dude, thanks for sharing!
josecheca
This is looking great! Thanks Aoktar
dinf
Many thanks both of you!
Great explanations Ahmet!
| Win 11 | 64 GB RAM | AMD 5900X | RTX 3090 24 GB | C4D R21 | C4D-Octane v2026.1 |
EOA
Is it a bug that there is no dispersion in the specular sub-material when using the new blend material?
Is there any documentation on this blend material anywhere to be found I've been googling all day with no luck.
EOA wrote:Is it a bug that there is no dispersion in the specular sub-material when using the new blend material?
Why do you need document? Everythings is same as in Octane materials.
FAZ
Hello aoktar,
3.08 will not work. I've tried all 388.xx drivers and higher.
Windows 10 Creators - 1803 (update forced by Windows 10)
MOBO: Asus X99-E WS Usb 3.1 (yes PLX)
Driver: Only 382.33 works (Even with RedShift!)
GPUS: x3 1080s, and x1 1080 Ti
Octane 3.07 stable with 382.33 only
Newer drivers cause freeze. BSOD watchdogs if left on while frozen. I've tried all of the drivers from 388.xx and up.
Any suggestions/solutions would be greatly appreciated! lol Losing my mind here. :shock:
www.alexdimella.com IG @alexdimella
Tag12345
FAZ wrote:Hello aoktar,
3.08 has been weird with the new Nvidia driver period. I had to back date to 370 or so a stable. but rumor has is to wait for v4 next week. getting confirmation
