OctaneRender 3 for Rhino (OBSOLETE)
Could you make the new demo plugin for Rhino?
when you update the new version of the time, could you release an official version and a demo version?
I'm sorry, but I only release a demo version on an irregular basis - usually after a large functionality change.
I have added a link to the top of this thread to the Rhino 6 build of the plugin. Pls consider it to be experimental - and not for production work. It is built with Octane 3.06.2.
prehabitat
What!? Did they lock down the SDK?
Win10/3770/16gb/K600(display)/GTX780(Octane)/GTX590/372.70
Octane 3.x: GH Lands VARQ Rhino5 -Rhino.io- C4D R16 / Revit17
I am not sure what you are referring to.
fabrizio_s
face_off wrote:I have updated the installer at the top of this thread with:
3.6.1.83
- Compiled with Octane 3.06.1
- The plugin will now ask for an environment missing texturemap
- Added "10%" to the Viewport Zoom combobox
- When changing the Viewport zoom combobox, the plugin will now attempt to set the scrollbars such that the object at the center of the viewport is centered for the new zoom amount. This is experimental functionality, so pls report any adverse findings on this
- Fixed a number of rounding errors which were leading to the color selection dialog to not functioning correctly
- Changed the Collapse button to always collapse the whole material regardless of which pin is selected
The subscription version should be available from the download page in the next few days.
- 10% works fine!
- auotocenter...some times doesn't works as expected
- collaps is great!
thanks a lot
fabrizio
eric_clough
Hi Paul ...
I downloaded what I thought was a version that will run with the Rhino 6 Beta but can't figure out how to get it installed.
Help please
eric
Win 8.1,16GB,i7,GeForce GTX760(4GB),(GeForce 334.89 driver, GeForce GT640(4GB) Dual 27" monitors
Same as Rhino5 - drag the .rhi file onto the Rhino6 desktop.
eric_clough
Hi Paul ..
THanks
but
Where do I find the .rhi file?
eric
As per my post above, the link for the Rhino6 installer for the plugin is in the first post in this thread.
eric_clough
Thanks Paul ...
Got it. it is now up and running.
eric
Return to “Rhinoceros 3D”
