I don't know if anyone experience the same issue like i have now, This version seems very slow to open octane render viewport comparing with previous version (1.2)
With the same object models it took around 25 minutes to open render viewport, but it took less than 5 minutes with version 1.2
OctaneRender® for 3ds max® v1.50a
3x GTX Titan - Win7 Pro x64 - Intel i7-3930K - ASUS Rampage IV Formula-X79
Do you use mesh smooth, turbo smooth, or some other modifiers with different settings for viewport and render?rfox wrote:I don't know if anyone experience the same issue like i have now, This version seems very slow to open octane render viewport comparing with previous version (1.2)
- GlobalMarketing
Hi Karba
what is this ?
Can you help me ?
what is this ?
Can you help me ?
not all that you mentioned above, just regular objects from sketchup. i switched back to 1.2 for now.Do you use mesh smooth, turbo smooth, or some other modifiers with different settings for viewport and render?
At this stage, I think version 1.2 is more faster and stable comparing to 1.50a.
Yesterday I had the same issue. I had one object which has turbosmooth off for viewport, 2 iterations for render.rfox wrote:not all that you mentioned above, just regular objects from sketchup. i switched back to 1.2 for now.Do you use mesh smooth, turbo smooth, or some other modifiers with different settings for viewport and render?
It's painfully slow in OCtane viewport. What I did was I turned off render setting for the turbosmooth.
That helped.
This has to be solved Karba..
In the old days it Smoothing at render wasn't working even it was set.
Now I have to think if the scene has that kind of Tsmooths or not.
My Portfolio
What is your GPU, power supply, GPU temperature in the middle of an animation?suvakas wrote:Sometimes the animation rendering stops on some random frame.
GPU's are idle, but the rendering process dialog is open and does nothing.
Also please add the shutter speed option.
Suv
Are you expecting render iterations just magically appear in octane viewport without any time/memory/speed issues/downgrades?oguzbir wrote:
That helped.
May I have your scene?rfox wrote:not all that you mentioned above, just regular objects from sketchup. i switched back to 1.2 for now.Do you use mesh smooth, turbo smooth, or some other modifiers with different settings for viewport and render?
[email protected]
