Thanks Refractive Team!
Chris
OctaneRender® 1.025 b2.55 test release [Obsolete]
single sheet SSS ? can you explain that please ?
Also, I'm off to bed now, it's very late here
Thanks for your responses, I really hope to see the WIP and Gallery forum plastered with SSS renders tomorrow
Radiance
Radiance
Gabrielefx means the simulation of a thin thickness without haveing a thickness at all. (Simulating SSS on a single surface).
Wow, great work ! This is really a huge improvement ! Thank you Refractive Team !
I just see the quote above. I wanted to ask the same question about the use of SSS on thin things like rose petals or tree leaves : As SSS is supposed to be due to refraction in the thin layer inside the material, under the surface, is it necessary to give an actual volume for the petals ? Are they extruded with some thickness ? Or is SSS faked on simple surfaces (faces) without thickness ?Gabrielefx means the simulation of a thin thickness without haveing a thickness at all. (Simulating SSS on a single surface).
- Elvissuperstar007
- Contact:
You can make it easier .. like other renderers
simply choose SSS
I do not understand how to use it (((
simply choose SSS
Can you share the setting of your material??Please!vimaxus wrote:Impressive! I got this after an hour...
SORRY, MY ENGLISH IS BAD!
2 Xeon quad core E5440_8gb Ram_Nvidia GeForce 2GTX 780ti 3Gb/Nvidia Quadro K2000_Win10 64bit_Octane 3.02_Rhinoceros3D
+1 for thatDaniel79 wrote:Can you share the setting of your material??Please!vimaxus wrote:Impressive! I got this after an hour...
and if you do, plz use the live-db
