Soft2Octane 2.52c [Obsolete]
Autodesk Softimage XSI (Developed by Face)
jamnique
face wrote:
jamnique wrote:I haven't seen the message either, but last night i managed to render 500 HD frames in a row, and that is a first. Great job, thanks! ;]
I have one question / request: could we get a slider to animate Stereo Distance in some future version?
Sure, when you can say me the hidden commandline parameter ;)
face
Ah, so that's how it is. Rendering eyes separately it is then ;]
Intel Core2Quad 9200 / 4 GB OCZ / Gainward 460 2GB
PeterCGS
Uhm, does anyone else experience problems getting Soft2Octane to run on 2012 service pack? We just installed it on a new workstation, and no matter what we do. Octane wont show up in the file export list, and if we try to load a scene with Soft2Octane already in there, it says Soft2Octane is missing? This was very confusing.
Win7, i7 980 Hexacore, 24GB RAM, 3xEVGA SC 670 GTX 4GB
face
PeterCGS wrote:Uhm, does anyone else experience problems getting Soft2Octane to run on 2012 service pack? We just installed it on a new workstation, and no matter what we do. Octane wont show up in the file export list, and if we try to load a scene with Soft2Octane already in there, it says Soft2Octane is missing? This was very confusing.
The problem can be, that the plugin saves the filepath from the Octane.exe to the .ini-file only, when you open or close the PPG.
If you change some parameters after changing the Octane.exe and you don´t reload the PPG, means close or open, it can be,that the old path is used.
Maybe you can try to to change the path to the OCtane.exe, close the PPG, open it again and try to render...
face
http://vimeo.com/user2509578
PeterCGS
When I go into View->Toolbars->Octane and the click the Octane icon I get this message:
' ERROR : 2000 - Argument 0 (PresetObj) is invalid
' ERROR : 2027-PROP-SIAddProp - Invalid preset argument, cannot load Soft2Octane
SIAddProp "Soft2Octane", "Scene_Root", siDefaultPropagation, "Soft2Octane"
' ERROR : Invalid procedure call or argument: 'SIAddProp' - [line 18]
' ERROR : (Microsoft VBScript runtime error)
' ERROR : [16] (null)
' ERROR : [17] function gen
' ERROR : >[18] SIAddProp "Soft2Octane", "Scene_Root", siDefaultPropagation, "Soft2Octane"
' ERROR : [19] inspect
' ERROR : [20] end function
InspectPreferences
If I go into the plug-in manager, the working version looks like this:
Soft2Octane
Plug-ins
FilebrowserPlugin
Filebrowser (Custom Command)
Soft2Octane
Soft2Octane (Property)
&Soft2Octane (Menu)
Soft2Octane (Menu)
SPDLs
Toolbars
Octane.xsitb
The non working version looks like this:
Soft2Octane
Plug-ins
FilebrowserPlugin
*Error* (Red icon) Soft2Octane ->When I check with edit it says Library not found:
C:\Users\........\nt-x86-64\Octane_x64.dll (The filepath is correct though?)
SPDLs
Toolbars
Octane.xsitb
Does it give you a better clue to understand whats wrong?
/Regards Peter K
face
Here the complete filepath for x64 is:
C:\Users\xxx\Autodesk\Softimage_2012_Subscription_Advantage_Pack\Addons\Soft2Octane\Application\Plugins\bin\nt-x86-64\Octane_x64.dll
Maybe the xxx username has spaces?
face
PeterCGS
Nope, nothing strange about the filepath..
C:\Users\Dick\Autodesk\Softimage_2012_Subscription_Advantage_Pack\Addons\Soft2Octane\Application\Plugins\bin\nt-x86-64
When I compare to my computer, everything looks the same, and we both run Win7 etc etc.. You can't think of anything else that should be installed like Microsoft Visual C++ 2008 etc etc?!? I thought it had something to do with the UAC or something, but can't find anything odd.. Pretty clueless here :(
/Regards Peter K
face
I haven´t changed anything in the UAC on my computer.
Have installed Microsoft Visual C++ 2010 x64 Runtime - 10.0.40219,
Microsoft Visual C++ 2010 x64 Redistributeable - 10.0.30319,
Microsoft Visual C++ 2008 x86 Runtime - 10.0.40219,
Microsoft Visual C++ 2010 x86 Redistributeable - 10.0.30319
and some 2005 and 2008 Redistributables.
The filetree looks like this:
face
EDIT:
When it helps, we can communicate with msn or skype...
PeterCGS
Visual 2010 C++ did the trick! It wasnt installed on the other computer.. Installed it and, whopp! It works! Thanx Face!
face
Hm, maybe because i had switched from Visual C++ 2008 to 2010 to compile the plugin.
But good to know...
face
DI2011
Hi Face,
I have uninstalled 2.52B to install 2.52C
But When I Istall this new version, nothing happens...
I can´t find exporter in softimage 2012.
I never had some kind of trouble with this plugin installation..
Am I doing something wrong?!
Windows 7 Ultimate 64-Bit, Intel I7 980x Extreme, 6GB ram, Nvidia Geforce GTX 580
Return to “Autodesk Softimage XSI”
