Ok, but for "real" simulation?PhilBo wrote:You can use the floatHemi data type which allows you to position the sun by X,Y coordinates and Z for the angle, so that you can position it any way you like.pixym wrote:Oh this Sunday would be nicer after seeing that
Just one important question for archivizers as me: Is there an option for offsetting North angle in case your scene does not suit 90° North?
Red Room 1.0 Beta 2 Sun Sky Test
Work Station : MB ASUS X299-Pro/SE - Intel i9 7980XE (2,6ghz 18 cores / 36 threads) - Ram 64GB - RTX4090 + RTX3090 - Win10
Net render : MB Asus Pro WS W790E-SAGE SE - XEON - 128GB - 2 x RTX 3090 - 3 x RTX 2080TI
there's a world map you can click on and enter date/time, just look at philbo's video.pixym wrote:Ok, but for "real" simulation?PhilBo wrote:You can use the floatHemi data type which allows you to position the sun by X,Y coordinates and Z for the angle, so that you can position it any way you like.pixym wrote:Oh this Sunday would be nicer after seeing that
Radiance
Radiance, I see that the worldmap, it is quite the same with some other apps.
What I would like to know is that:
As an old architect and also archivizer I am able to draw site plan with North not quite at 90° from my ruler. Sometime, North can be 20° or other value offset to regular 90°. It is what I call offset angle and is is very important. Otherwise, you need to rotate your scene to have North at 90°.
I can add a rotation option if you want ?pixym wrote:Radiance, I see that the worldmap, it is quite the same with some other apps.
that's not a bad idea.
Radiance
That would be very usefull. Thank you very very much for your listening.radiance wrote:I can add a rotation option if you want ?pixym wrote:Radiance, I see that the worldmap, it is quite the same with some other apps.
Radiance
