Cinema4D version OctaneRender® 2024.1_Alpha3 (21.02.2024)
Delizade
I started to use 2024.1_Alpha3 (21.02.2024) recently and there were some issues. I wanted to share my raw report here (I would want to make deeper tests but couldn't for now)
1) Sometimes all Image Texture node previews goes black. Node details show correct previews.
2) Noise nodes shows red preview. Node details show correct previews
3) if a material has both active anisotropylevel and displacement, LV produces weird results (attached)
(In another project, material has only displacement node active and that project was being rendered weird too. So I couldn't be sure which was triggering the problem)
4) In the test.c4D project file, while LV active, adding a simple plane object and dragging it produces error, same error comes while editing material. (log attached)
https://drive.google.com/file/d/10CfXBN ... sp=sharing
astrofalcon
Any new builds to test? Is this the latest?
frankmci
astrofalcon wrote:Any new builds to test? Is this the latest?
Yes, Alpha3 is currently the latest.
viewforum.php?f=85
jmachemer
With the new version of Redshift coming out featuring an extremely powerful toon shader, is there any chance of an update on the Anime kernel that has been in development for some time?
