Getting real mad now
matej
There is a limitation on the number of texture objects CUDA can handle, I don't remember the exact numbers (look it up in the manual), but in reality this is not a limitation, because you can merge the textures if needed be. This is a Nvidia/CUDA thing, so blaming RS or Octane for it is like blaming them for the limited amount of RAM on today's GPUs.
cgmo.net
matej wrote:There is a limitation on the number of texture objects CUDA can handle...
Not so. This is not limitation of ABILITY, but limitation of CONVENIENCE of programming. This limitation can be avoided by programmer IMHO.
I wrote about it HERE.
matej
There must be a valid reason RS complied to that kind of programming. But anyway, in reality, how often do users bump in to this problem? I never have and I do image-texture intensive rendering.
Unless you have lots of small textures and a "special" texturing workflow, you won't have problems with this.
cgmo.net
hmk
matej wrote:There must be a valid reason RS complied to that kind of programming. But anyway, in reality, how often do users bump in to this problem? I never have and I do image-texture intensive rendering.
I had this problem in several scenes, so it happens and it is extremely annoying. The solution in such case is to try to reuse rue textures and use procedurals.
http://www.OctanePowerTools.com
Octane Render Power Tools, Animation Tools for Octane Render
facebook | YouTube
Intel Core i7 920 @ 2.67GHz - RAM 12.0 GB
Asus P6T7 WS SuperComputer GTX 480
TheOracle
Yes,
Like i said in the beginning in 4 out of 5 projects i had to do recently!
2 with complete cities and 3 complex motion graphics pieces.
+ Like i said, i don't know how to change ena create UV maps, so that's no solution to me. (my collegue who was alreaddy paid did this)
And then again, it renderd in many other external renderes like 'Indigo' just fine. So why can't octane get inspired by that?
So if Nvidia gives some trouble, don't make the basic code dependent on that.
I just want to animate what i have to animate and render. I would not get mad if this happend just once in a long time.
Win 10 64 bit + Linux Ubuntu | Nvidia RTX 2080TI | AMD Ryzen Thredripper CPU 2970WX 24-Cores/48-Threads | Houdini - Cinema 4D - Maya - 3Dsmax
zivko
i know this is OT, but you do realize you're using beta software? problems are to be expected in the state octane is in and rs guys are working on fixes and adding new stuff all the time. raging about your problem wont help, either find a way to make use of suggestions other members posted or stick with non-beta rendering engines for your work
desktop - win7 64bit, i5-4690, 12gb ddr3, 970gtx 4gb, 460gtx 2gb
laptop - win7 64bit, i7-2630qm, 10gb ddr3, 550m 2gb
t_3
TheOracle wrote:So if Nvidia gives some trouble, don't make the basic code dependent on that.
if octane gives some trouble, don't make your professional work dependent on that.
sorry if that sounds rude, but if you - or whoever decided it - uses a specific piece of software for a job, he should know about its limitations. and there are always some...
The obvious is that which is never seen until someone expresses it simply
tehfailsafe
It sounds like your collegue is freelance, no? If so It seems the modeller would be responsible for making his files in a workable format for the renderer ( ie. whatever you tell him it needs to be ). If your job is to animate / render / direct, then direct. If you don't know how to layout uv's surely he does ( as he did already ). Provide him the specs you need ( combine 4 512x512 textures into 1 1024x1024 texture ) and he should have to accommodate to the requirements.
Several times I've had to adjust work because the guy running the final composite couldn't figure out how to correctly apply the UV pass in AE, so I had to re-render out the overlay graphic without the model. And I'm about to do yet another one on that same project because now it needs a TM next to the logo...
windows 7 64 bit| GTX580 1.5Gb x2 | Intel 2600k @ 4.9 | 16gb ddr3 | 3ds max 2012
