OctaneRender 2022.1.2 for Houdini production (2022.1.2.0)
ricky_otoy
I tried as you did and not getting the issue at all, even rendering to file multiple times.
What exact Houdini version and plugin version are you using? I assume from your sig that you are using Windows 10, is that still correct?
galleon27
I am using 19.5.640, windows 10.
Win 10 64bit // GTX 4090 + GTX 3090 // 5900x // 64GB // SideFX Houdini // C4D
galleon27
Ok so i figured out what the problem was, at least for me. The bug happens when i use disable DOF in the IPR.
ricky_otoy
galleon27 wrote:Ok so i figured out what the problem was, at least for me. The bug happens when i use disable DOF in the IPR.
Thanks for that, yes I can confirm that I get the same result now - I have logged an issue for this.
Tipix
Hello,
I have a crash every time I close the IPR window with all my GPUs active but no crash when I only have only 4090rtx without 3080.
This issue was present in the previous version too.
3x 4090 2x 3080 1x 3080ti || 128Go || Win 11
ricky_otoy
Tipix wrote:Hello,
Hi Tipix, can you please send us a log. Enable it under Octane Options > Debug.
