maybe your glass has to mutch roughness (turn it to zero) ? This could be the reason why it looks like a sss material.
Use the PMC kernel and fireflies should go away. Or turn on "Fireflies reduction" in Octane.
23 hours seems to be a very long rendertime, I normaly have better results in a shorter amount of time.
In PMC or PT you can reduce the "Bounces" (can not rememer how it it's called exactly) from 16 to 8. It make the rendertime shorter and quality is still good enough.
There is a Photoshop plugin called Topaz Denoise to reduce noise (fireflies) which should also work for Gimp, see here:
http://www.pentaxforums.com/forums/digi ... -gimp.html
Isn't there a plugin called "citymaker" (or something similar) for Blender ?
I'm always glad when I can help
Kind regards
Alain
