OctaneRender® 1.0 beta2.52 >>> download here <<< [OBSOLETE]
dhamoeba
congratulation!
my best friend who taught me mental-ray years ago(he's one of the render masters in our school) is working for a lighting design firm. after comparing i-ray and octane he's also looking forward to octane render! cheers! :)
Win 7 x64 | GTX780Ti | Phenom II X6 1090T | 16GB RAM
acc24ex
refractive
matej
Marcus, I don't know what you guys did, but on my system (Linux, single GPU) the GUI responsiveness during rendering is much, much better in this version!
Even on medium sized resolutions the lag barely impacts work, which is amazing. :shock:
You definitely hit the spot, with this one 8-)
Keep up the good work!
cgmo.net
retmia
I though it would make it, but it didn't!
Any trick to make the color bleed trough glass looking material in direct light? Do you plan to add the feature?
Thanks for everything, regards! :)
retmia.net
retmia.blogspot.com
i7 3930k - 2x ASUS GTX590 - 16GB DDR 3 - Corsair AX1200
Chris
The thin lens camera node does not work. None of the parameters react when moving the sliders. I tried replacing the node, but that didn't work either.
Chris
________________________________________________________
Win 7 64 | 1x GeForce GTX Titan | AMD Phenom II X6 3.20Ghz | 16GB
abstrax
Chris wrote:The thin lens camera node does not work. None of the parameters react when moving the sliders. I tried replacing the node, but that didn't work either.
Chris
Here it works, could you please be more specific? Are you sure that you are modifying the correct camera node?
Marcus
Jaberwocky
Chris
Chris
It works for me.Added a thin lens node to the scene.
set up a different viewing angle and camera angle.
Then i just connected each node in turn when i wanted the new camera point of view.
See image
radiance
retmia wrote:I though it would make it, but it didn't!
These are caustics and are indirect light.
They are only possible with pathtracing and pmc kernels...
Radiance
PaperTurtle
I haven't been keeping up to date with octane in a while. Has there been an overhaul on how things are loaded into the rendering engine now? I tried rendering some objs. And some old octane scenes. I don't seen anything at all. It doesn't sound like my video card is doing anything.
Edit: I opened an older version of octane. I click the mesh obj and the mesh begins to render. Nothing happens in this new version.
abstrax
PaperTurtle wrote:I haven't been keeping up to date with octane in a while. Has there been an overhaul on how things are loaded into the rendering engine now? I tried rendering some objs. And some old octane scenes. I don't seen anything at all. It doesn't sound like my video card is doing anything.
What does the status bar of the render viewport say? Can you render a diffuse material?
Marcus
