Office interior + final render reupload on 1 page
radiance
if you want to do a fair comparison algorithm-wise, you should render with progressive pathtracing in vray.
Radiance
Sam
Maybe that's because you are working in linear gamma inside Vray
there is currently no reverse gamma correction yet in octane
Can you explain a bit more ?
The output gamma of the viewport is 1
You mean textures are not gamma corrected by default ?
Try to make another example with same gamma in both engine
And like Radiance said, use progressive pathtracing
Good tests ;)
andrian
radiance wrote:if you want to do a fair comparison algorithm-wise, you should render with progressive pathtracing in vray.
Radiance
Yeah I thought of that :roll:
radiance wrote:you can play with the gamma.
there is currently no reverse gamma correction yet in octane,
so play with your imagetexturenode gamma slider.
Radiance
Seem my bad, when I exported the scene, maps was "corrected" by 3dsmax to gamma 0.45 and that caused dark and barely visible textures, I will render another pic with right textures. And it seems , size of the textures was not the issue for scene to take 460 mb of my vga ram, it was bad export settings.
nuverian wrote:Well, both seem good..They seem very similar as far as rendering goes, regardless of the exposure or gamma of the specific pictures. Octane's render seem a bit dark and vray's render seems a bit washed out. Indeed the textures are nearly visible.
Will you do a Fryrender as well?
Yep, but fry version will have to wait a bit.
Vista 64 , 2x Xeon 5440 - 24GB RAM, 1x GTX 260 & I7 3930 water cooled - 32GB RAM, 1 x GTX 480+ 1x8800 GTS 512
CGsociety gallery
My portfolio
My portfolio2 - under construction
Web site
Making of : pool scene - part1
andrian
Another one, I'm getting more and more excited , this time gamma 2.2, pathtrace on, render time on the info bar.
I cant stop :D
CGsociety gallery
My portfolio
Web site
[gk]
I wrote a tutorial about linear workflow in 3dsmax, related though not relevant for octane.
But I see alot of renders here ( on forum in general ) with wrong gamma space.
http://www.droschler.dk/Tut-LWF.html
Amiga 1000 with 2mb memory card
andrian
I'm using the same technique.
CGsociety gallery
My portfolio
Web site
radiance
Sam wrote:Maybe that's because you are working in linear gamma inside Vray
Good tests ;)
yes they are but not RGB values currently...
Radiance
buda
hello, so dark images can be corrected in Photoshop, for example through the options in the menu Image> Adjusments> Shadows / Highlights ... or in menu Image> Adjusments> Levels. See example
cuda
