That's a good point, I can't think of any reason you shouldn't be able to tweak settings in final render mode. I'll make a note to loosen up these restrictions at some point.SiliconAya wrote: Ah ok, makes senses, I'll turn it off. I haven't used the final button in years, I stopped using it at some point as there was no benefit. Now there's a reason(s) to use it. Although, not being able to tweak imager settings once you've pressed final is a pain, I've become used to tweaking the ones that don't restart the render whenever I want. Would that be something that could be allowed in the future?
Ah, gotcha. Thanks for confirming the workaround. I think the problem here is that I recently disabled live geometry updates in final render mode (it was causing problems with animations) but the way mesh smoothing works in Daz is it happens in the background, so by time it finishes the final render has already started and the smoothed geometry is ignored. What I'll do is to temporarily turn on Interactive Update while entering final render mode (the same thing that is already done when rendering animations).SiliconAya wrote: When I said the same as when it's turned off, I meant exactly the same, they're identical for me. Also, the clothing I just tested it with today doesn't have SubD, not sure if the clothing from the previous render had SubD or not, but in this case view and render levels can't be different, because it's not using SubD. However, turning on "Interactive Update" does stop the issue from happening.
Toby.
