OctaneRender® for 3ds max® v2021.1 - 12.09
paride4331
mbetke wrote:Yes. I already updated Studio Drivers yesterday to the new 500 series.
Can't tell what causes it.
Hi mbetke,
Studio driver, right?
mbetke
Yes. Of course. With a clean installation using "Display Driver Uninstaller".
PURE3D Visualisierungen
richardyarlett
SOLUTION TO DENOISED BEAUTY PASS
3DSMAX users.. found a bug in the lastest version 2021.1 - 12.09
It seems that unless you add the DENOISED BEAUTY pass added to your RENDER ELEMENTS, it will ignore the beauty pass as the primary output and only output the raw noised pass, EVEN if you have selected that option in the TOOLS > OPTIONS setting.
paride4331
richardyarlett wrote:SOLUTION TO DENOISED BEAUTY PASS
viewtopic.php?f=80&t=78980#p408521
richardyarlett
PARIDE ??? CAN you confirm my findings ?
richardyarlett
NETWORK RENDERING CONFIGURATION BUTTON
The network rendering configuration button does not appear to do anything. It does not work. It creates no new interface or popup.
paride4331
richardyarlett wrote:NETWORK RENDERING CONFIGURATION BUTTON
is not that by chance you have installed the Octane Render Studio instead of Octane Enterprise version?
Regards
Paride
samsue
oh man... those new tex/mtl nodes! top!
a little strange organized... but it gave a nice UP in the workflow
Jani
I have a forest pack problem after installing this latest version, in that any time I try to run octane with direct mode enabled and a forest pack object present, I get an instant crash.
I've got a link to a video which describes this available here:
https://drive.google.com/file/d/1pt9aXq ... sp=sharing
and an empty max file with the Octane preset helper here:
https://drive.google.com/file/d/1ahBp0h ... sp=sharing
Please try to fix this.
Thanks!
i9 9920X, 64GB, RTX 2080Ti
Ryzen 1800x, 64GB, 2x RTX 3090
Templas
Hello, I have an error when rendering a beauty pass in PNG format, just black and white stripes (Alpha enabled), if render in EXR, then everything is fine.
