LDR Multi-Pass images with OCIO
Meet
aoktar wrote:Png is marked as sRGB for saving if you are using it with default sRGB. But any OCIO profile is assumed linear. Set it as linear on saving.
I am sorry, I don't quite understand what you mean, are you suggesting after the image is exported I change it to linear in a compositing software?
If not, then can you tell the steps to get final image + render passes with OCIO baked-in in png format?
Ryzen 9 5900x | 64GB RAM | 1x RTX 3090
Blender | C4D | Standalone
Win 10
Pretty easy, you need to set it "LINEAR" because OCIO is linear internally. And always disable "ENABLE COLOR PROFILE" in PICTURE VIEWER. It's giving headhaches because it's not aware of the colorspace we're using.
Meet
aoktar wrote:Pretty easy, you need to set it "LINEAR" because OCIO is linear internally. And always disable "ENABLE COLOR PROFILE" in PICTURE VIEWER. It's giving headhaches because it's not aware of the colorspace we're using.
I am still not getting the expected results, the passes don't export with ACES OCIO - sRGB.
Sharing the c4d file along with the expected results which I got via file > save image as on the octane live viewer.
Now I am only asking how can I save the passes in png with ACES srgb baked in without saving it manually from live viewer
The passes with ACES- sRGB baked in
OCIO test.rar
C4D file
(911.3 KiB) Downloaded 96 times
Win 10
jayroth2020
Hello Meet,
Set up your Render Settings panel as I have in the screenshots. You will need to set up both the Main tab AND the Render AOV Group tab as you see in these images. When you do, you will end up with the image that matches the one I have included. DO NOT USE THE CINEMA 4D SAVER.
+1 for Jayroth and +2 for: Why do you desperately trying to use PNG for render passes tooo?
It's wrong to insist to save render passes with sRGB. You cannot use these for comping. I see you're probably trying to just use "refraction" and "light direction". But don't apply sRGB colorspace before displaying something.
Please choose the ways we advice for render passes as much as possible.
Meet
jayroth2020 wrote:Hello Meet,
Thank you Jay, but I have set the settings just as you suggested and I am not getting same result as you via the octane export. I am getting the same result on my c4d picture viewer though, with viewer color profile set to linear
aoktar wrote:+1 for Jayroth and +2 for: Why do you desperately trying to use PNG for render passes tooo?
I understand and agree that EXR workflow would be ideal, but I am was using octane with blender before and this workflow was working pretty fine so I thought I was making a mistake in C4d to get the same results, so to clarify I made a forum post.
Okay so after previewing the message before submitting I understood that there is some issue on my end/understanding as the same exported photo looked different to me on my image viewer as compared to the same photo I uploaded on this post (probably something to do with HDR buffer?)
Now I can verify that I was getting the right result all along, just was viewing it in the wrong place.
For example both these png images look same inside fusion
All are the same image opened via different softwares
Thank you.
Win 10
