OctaneRender™ 2021.1 RC 3
coilbook
Anyway to add an info how many total cuda cores engaged. How many RT cores are engaged. Percentage of cuda contribution vs rt cores towards rendering speed.
Sometimes we turn on RTX acceleration and see no results like it's not working. Would be nice to show all this data
abstrax
coilbook wrote:Anyway to add an info how many total cuda cores engaged. How many RT cores are engaged. Percentage of cuda contribution vs rt cores towards rendering speed.
There isn't really a good way to measure this. If you enable RTX Octane tries to use RTX as much as possible, but at the moment this applies only for static triangles and instances. So if your scene uses a lot of texture displacement, vertex motion blur, hair etc. it won't help much.
Zay
abstrax wrote:There isn't really a good way to measure this. If you enable RTX Octane tries to use RTX as much as possible, but at the moment this applies only for static triangles and instances. So if your scene uses a lot of texture displacement, vertex motion blur, hair etc. it won't help much.
Is there a way to calculate used Vram better? In a scene when I turn on or off RTX no changes show in Vram in Octane but GPU-Z shows 1.3GB Vram difference.
Win 11 Pro | i5 12600K | 32GB ram | 2x GTX 1080Ti + 3080Ti - studio driver 581.57| Modo/Blender/ZBrush/Daz/Poser
rleuchovius
Great work!
Do you have any estimate on the Polarized Lighting? Would be a very useful feature for car renders. :)
HHbomb
Hi, could it be possible to have "Round edges" applied with "clipping material" ? Because it make hard edges.
wallace
HHbomb wrote:Hi, could it be possible to have "Round edges" applied with "clipping material" ? Because it make hard edges.
It is not possible at the moment, I am working on an implementation for clipping material to work with rounded edges.
HHbomb
Thank you wallace. Hope it'll be possible :mrgreen:
useruser
hi there,
i am not able to start the OctaneRender_Enterprise_2021_1_RC_3_node on my renderslave-machine. during the login-process the node just quits and kill itself.
the Octane 2020.2.5 Daemon works fine.
is that a known issue?
thanks in advance
Workstation: Win 10 PRO 64 bit, 3,4 GHZ ,6-cores, 64 GB RAM , 4x RTX 2080 Ti
1. RenderSlave: Win 10 Pro 64 bit , 3x GTX 980Ti
2. RenderSlave: Win 10 Pro 64 bit 2x GTX 980 Ti
john_otoy
useruser wrote:hi there,
thanks in advance
OctaneRender 2021.1 was released: viewtopic.php?f=24&t=78621
Please try with the latest build and reply in that thread if you have any issues.
vijay
elsksa wrote:Hi OTOY Team,
I did not share my gratitude towards this stunning release (considered now, at the time of this reply, "deprecated"). In particular the important fixes.
However, I am facing an obnoxious behavior since this release and any versions higher: on some scenes containing USD assets, my materials (nodes) are no longer applied to the USD geometry node. The imported USD assets is using default materials and my custom materials do seem to be lost.
My current workaround is to have two Standalone instances opened, both different versions and copying/pasting my nodes to plug them back again (using the speed-efficient and useful CTRL + HOLD shortcut as I am assigning materials to a custom assets/shading group nomenclature).
I also have back up files and I am aware that these builds are non-production-safe.
I suspect this fix is the cause behind it:
abstrax wrote: [*] Updated USD library to version 21.08.
I can handle the extra manual work, however, I would be curious if I could get a confirmation of my suspicion.
Hi Elsksa,
Thanks for the report. I'll look into it. Since you said the behaviour is happening only in some scenes, it would be better if I get that ORBX file. Could you please forward me the scene if you can able to do so.
Vijay
